Aller au contenu principal
Introduction
Read me: This guide is archived. Many laptops covered by this have failing feet and most 3rd party replacements are anti-slip. In addition, modern 3rd party feet do not fall off easily and make a mess like most non-slip pads. Unless your OEM feet are still intact, it is best to remove the original set and upgrade them with anti-slip replacements using this guide: (Inner plug) How to Remove the factory feet from a Mac Laptop
If your Mac laptop is running hotter then you would like, this guide will show you how to install rubber feet to lift the laptop to allow for additional cooling of the system.
Read before starting: While this guide will help reduce the temperature your Mac runs at, early systems (2006-2012 MacBook/Pro) will always run hotter then Retina systems by design. Apple relies on the ports to provide fresh air for the chassis and reuses the hot air in the system. This is not an issue with the rMBP. These laptops have real cooling and will see reduced temperature drops.
13" MacBook Pro only (Optical drive/Retina): 13" models lack a dGPU. These systems will not see as much of a temperature reduction as there is less heat the system needs to disperse due to this omission. This does not apply to dGPU systems (15”/17” MacBook Pro).
In the original guide, the author used a Early 2009 17” MacBook Pro was used by the author. Before this fix, the system regularly ran up to 180° F without taller feet. The operating temperature was reduced to 122° after adding taller feet.
Outils
Aucun outil spécifié.
Pièces
  1. Do not install the replacement feet on top of the factory installed feet. These may break off if the system is moved in the right way.
    • Do not install the replacement feet on top of the factory installed feet. These may break off if the system is moved in the right way.
    • Place your MacBook upside down on a clean flat surface.
    • Clean the laptop surface with rubbing alcohol or a similar cleaner.
    • Identify where you would like to place your new rubber feet. The new feet should be placed somewhere near the factory installed feet. Avoid placing the new feet on curved edges.
  2. Peel the paper backing off each foot. Once this is done, install them onto the laptop. Peel the paper backing off each foot. Once this is done, install them onto the laptop. Peel the paper backing off each foot. Once this is done, install them onto the laptop.
    • Peel the paper backing off each foot. Once this is done, install them onto the laptop.
Ligne d'arrivée
11 autre(s) ont terminé cette réparation.
Nick
Membre depuis le 10/11/2009
48 404 Réputation
39 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
286 membres
811 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 8
7 derniers jours : 37
30 derniers jours : 190
Total : 23,912
