Aller au contenu principal
Palm IIIxe Screen Replacement
Ce dont vous avez besoin
  1.  Palm IIIxe Screen Replacement, Battery: étape 1, image 1 de 3  Palm IIIxe Screen Replacement, Battery: étape 1, image 2 de 3  Palm IIIxe Screen Replacement, Battery: étape 1, image 3 de 3
    • Turn the device over so it is face down and remove the stylus, and battery cover.
  2.  Palm IIIxe Screen Replacement: étape 2, image 1 de 2  Palm IIIxe Screen Replacement: étape 2, image 2 de 2
    • Now remove the two batteries by pulling on the cloth black tab.
    • Remember, when inserting the batteries, to keep the tab below them to make it easier to remove the batteries in the future.
    • If this tab is not visible, use the flat head screwdriver and gently pry out the batteries by pushing on the positive end (opposite the spring).
  3.  Palm IIIxe Screen Replacement, Motherboard: étape 3, image 1 de 3  Palm IIIxe Screen Replacement, Motherboard: étape 3, image 2 de 3  Palm IIIxe Screen Replacement, Motherboard: étape 3, image 3 de 3
    • It is recommended that you do the disassembly over a cookie sheet so you don’t lose any small parts . Zip-loc bags are great for keeping the four small screws all in one place.
    • Using a Philips #0 or #00 screwdriver, locate and unscrew the four screws holding the back cover on the device.
    • Make sure to keep these screws in a bag or somewhere you will not lose them.
  4.  Palm IIIxe Screen Replacement: étape 4, image 1 de 3  Palm IIIxe Screen Replacement: étape 4, image 2 de 3  Palm IIIxe Screen Replacement: étape 4, image 3 de 3
    • Take the plastic opening tool and insert into the seam between the two covers and pop off the cover then set it aside.
    • You may need to do this multiple places around the perimeter to undo all the snaps but it should come off with little pressure.
  5.  Palm IIIxe Screen Replacement: étape 5, image 1 de 3  Palm IIIxe Screen Replacement: étape 5, image 2 de 3  Palm IIIxe Screen Replacement: étape 5, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • This is a delicate part and may require a magnifying lens.
    • Locate the brown serial connector on the left side of the device. Using the flat head screw driver, push the little tabs (one on each side) out towards you as pictured.
    • They should extend about 1/16 of an inch (1.5 mm).
    • Now take the screwdriver/tweezers and gently pry out the serial tab as shown .
    • It is flexible but don’t bend it back and forth too much as it will eventually break.
  6.  Palm IIIxe Screen Replacement: étape 6, image 1 de 3  Palm IIIxe Screen Replacement: étape 6, image 2 de 3  Palm IIIxe Screen Replacement: étape 6, image 3 de 3
    • Take the plastic opening tool and gently pry the circuit board out of the plastic tabs around the perimeter located as shown.
    • You must also pry the circuit board away from the battery case (picture 2).
    • Now gently lift up the circuit board from the right side and set it on the cloth.
    • Remember, when reinserting the circuit board, insert it under the left tabs at an angle then gently press the right side down. (picture 3) Also keep the serial tab out of the way.
  7.  Palm IIIxe Screen Replacement, Button: étape 7, image 1 de 3  Palm IIIxe Screen Replacement, Button: étape 7, image 2 de 3  Palm IIIxe Screen Replacement, Button: étape 7, image 3 de 3
    J'achète
    • Use the tweezers, or your fingers, to remove the physical button strip.
    • If any buttons fall off the strip simply place them back on: they fit on in specific orientations so don’t force them on; look at the shape of the hole in the button.
  8.  Palm IIIxe Screen Replacement, Screen: étape 8, image 1 de 3  Palm IIIxe Screen Replacement, Screen: étape 8, image 2 de 3  Palm IIIxe Screen Replacement, Screen: étape 8, image 3 de 3
    • Use the ipod opening tool to pry the cover from the internal plastic frame; the internal frame and screen will come off at the same time.
    • This can also be done with just your fingernails if you wish.
    • Place the front cover aside.
  9.  Palm IIIxe Screen Replacement: étape 9, image 1 de 2  Palm IIIxe Screen Replacement: étape 9, image 2 de 2
    • The screen and internal frame should come apart easily. Set the screen on the cloth.
  10.  Palm IIIxe Screen Replacement: étape 10, image 1 de 3  Palm IIIxe Screen Replacement: étape 10, image 2 de 3  Palm IIIxe Screen Replacement: étape 10, image 3 de 3
    • For reassembly: Take the frame/screen assembly and line up the top left corner of it to the corresponding corner of the front cover. (two views shown)
    • Be careful not to tilt the screen too much as it will fall out of the plastic frame.
    • Now press the two parts together. Once together keep the screen facing down because it may fall out again.
Jacob
Membre depuis le 04/15/10
1 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 16-1, Maness Spring 2010 Membre de l'équipe Cal Poly, Team 16-1, Maness Spring 2010
CPSU-MANESS-S10S16G1
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 1,474
