Aller au contenu principal
1922 GE AOU Fan Power cord Replacement
Ce dont vous avez besoin
  1. 1922 GE AOU Fan Power cord Replacement, Power cord: étape 1, image 1 de 2 1922 GE AOU Fan Power cord Replacement, Power cord: étape 1, image 2 de 2
    • Tip the fan to its side and remove the three size 8 screws using a 9/32 flat-head screwdriver.
    • The screws may be brittle from age, so be careful.
    • Take the bottom plate off the fan and set it aside.
  2. 1922 GE AOU Fan Power cord Replacement: étape 2, image 1 de 1
    • Remove the three number 8 screws that hold the switch in place.
  3. 1922 GE AOU Fan Power cord Replacement: étape 3, image 1 de 1
    • Remove the switch, carefully sliding the speed lever out of its slot.
    • Don't remove the switch too quickly or you can damage the head-wire.
  4. 1922 GE AOU Fan Power cord Replacement: étape 4, image 1 de 1
    • Once the switch is free, unscrew the two knurled nuts holding the wires in place.
  5. 1922 GE AOU Fan Power cord Replacement: étape 5, image 1 de 1
    • Turn the switch over and unscrew the nut securing the wire with the 5/16 crescent wrench.
  6. 1922 GE AOU Fan Power cord Replacement: étape 6, image 1 de 1
    • Remove the switch and set it aside, then pull the wire through the grommet.
Elias Dorna
Membre depuis le 06/08/16
125 Réputation
1 tutoriel rédigé
Équipe
Texas Tech, Team 3-5, Rauch SU 2016 Membre de l'équipe Texas Tech, Team 3-5, Rauch SU 2016
TTU-RAUCH-SU16S3G5
2 membres
1 tutoriel rédigé
Un commentaire
Westinghouse table fan needs new cord (just bought). 18 gauge cord? Where to buy?
carol w - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 28
Total : 2,765
