Aller au contenu principal
1967-68 Mustang Kick Panel Speaker Replacement
Ce dont vous avez besoin
  1. 1967-68 Mustang Kick Panel Speaker Replacement, Kick Panel Speaker: étape 1, image 1 de 2 1967-68 Mustang Kick Panel Speaker Replacement, Kick Panel Speaker: étape 1, image 2 de 2
    • Find the car battery under the hood.
    • On the battery locate the black negative battery terminal.
    • Next unscrew the knob on the disconnect.
    • Lastly move the negative lead away from the batter terminal.
    • Make sure not to cross the battery leads.
  2. 1967-68 Mustang Kick Panel Speaker Replacement: étape 2, image 1 de 1
    • Locate the kick panel speaker that needs to be replaced.
  3. 1967-68 Mustang Kick Panel Speaker Replacement: étape 3, image 1 de 1
    • Locate the two top screws as well as the two bottom screws for the speaker.
    • Check the kind of screws that were used to hold the speaker in place.
  4. 1967-68 Mustang Kick Panel Speaker Replacement: étape 4, image 1 de 3 1967-68 Mustang Kick Panel Speaker Replacement: étape 4, image 2 de 3 1967-68 Mustang Kick Panel Speaker Replacement: étape 4, image 3 de 3
    • You are now ready to start replacing the speaker.
    • A philips head screwdriver will be needed.
    • Do not use a socket in this situation because it may mess up the speaker guard.
    • Lastly make sure to remove the screw completely without stripping out the screw hole.
  5. 1967-68 Mustang Kick Panel Speaker Replacement: étape 5, image 1 de 3 1967-68 Mustang Kick Panel Speaker Replacement: étape 5, image 2 de 3 1967-68 Mustang Kick Panel Speaker Replacement: étape 5, image 3 de 3
    • The speaker guard and speaker are now ready to be removed.
    • Be careful when removing the speaker. Do not pull the wires tight.
  6. 1967-68 Mustang Kick Panel Speaker Replacement: étape 6, image 1 de 2 1967-68 Mustang Kick Panel Speaker Replacement: étape 6, image 2 de 2
    • Locate the wires on the back of the broken speaker.
    • Remove both the positive and negative wires.
  7. 1967-68 Mustang Kick Panel Speaker Replacement: étape 7, image 1 de 2 1967-68 Mustang Kick Panel Speaker Replacement: étape 7, image 2 de 2
    • Now locate the new speaker.
    • Slide the positive and negative wires onto the speaker terminals.
  8. 1967-68 Mustang Kick Panel Speaker Replacement: étape 8, image 1 de 3 1967-68 Mustang Kick Panel Speaker Replacement: étape 8, image 2 de 3 1967-68 Mustang Kick Panel Speaker Replacement: étape 8, image 3 de 3
    • Place the speaker back into the kick panel housing.
    • Line up the speaker holes with the existing holes in the kick panel.
    • Be careful not to pinch the speaker wires.
    • This would be a good time to replace the speaker wires if needed
  9. 1967-68 Mustang Kick Panel Speaker Replacement: étape 9, image 1 de 2 1967-68 Mustang Kick Panel Speaker Replacement: étape 9, image 2 de 2
    • Place the speaker guard back over the speaker.
    • Screw in all four screws
    • Do not over tighten the screws or the holes will strip out.
  10. 1967-68 Mustang Kick Panel Speaker Replacement: étape 10, image 1 de 2 1967-68 Mustang Kick Panel Speaker Replacement: étape 10, image 2 de 2
    • Reconnect the negative battery terminal.
    • Screw the knob until it is snug.
You have now replaced the speaker.
John
Membre depuis le 09/29/15
101 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 15-7, Green Fall 2015 Membre de l'équipe Cal Poly, Team 15-7, Green Fall 2015
CPSU-GREEN-F15S15G7
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 17
Total : 1,646
