Aller au contenu principal
1980 -1990 Honda XR80R Carburetor Disassembly
Ce dont vous avez besoin
  1. 1980 -1990 Honda XR80R Carburetor Disassembly, 1980 -1990 Honda XR80R Carburetor Disassembly: étape 1, image 1 de 3 1980 -1990 Honda XR80R Carburetor Disassembly, 1980 -1990 Honda XR80R Carburetor Disassembly: étape 1, image 2 de 3 1980 -1990 Honda XR80R Carburetor Disassembly, 1980 -1990 Honda XR80R Carburetor Disassembly: étape 1, image 3 de 3
    • The Carburetor is located to the rear of the engine block, right under the gas tank.
  2. 1980 -1990 Honda XR80R Carburetor Disassembly: étape 2, image 1 de 2 1980 -1990 Honda XR80R Carburetor Disassembly: étape 2, image 2 de 2
    • Before beginning the disassembly process, first turn your fuel off by turning the dial located on the left side of the motorcycle, to the off position.
    • Disconnect the fuel line from the gas tank located on the the fuel dial.
    • Disconnecting fuel line may require prying with a flat head screwdriver.
  3. 1980 -1990 Honda XR80R Carburetor Disassembly: étape 3, image 1 de 3 1980 -1990 Honda XR80R Carburetor Disassembly: étape 3, image 2 de 3 1980 -1990 Honda XR80R Carburetor Disassembly: étape 3, image 3 de 3
    • Remove the rear plastic panels, one on either side, by unscrewing the two 8 mm screws located at the bottom of each panel, by using the 8 mm socket wrench.
    • Anytime screws are removed, they should be placed in container so they are not lost.
    • After the screws are removed, the panels can be easily pulled off with hands.
  4. 1980 -1990 Honda XR80R Carburetor Disassembly: étape 4, image 1 de 3 1980 -1990 Honda XR80R Carburetor Disassembly: étape 4, image 2 de 3 1980 -1990 Honda XR80R Carburetor Disassembly: étape 4, image 3 de 3
    • Remove the seat by unscrewing the two 8 mm screws located 2/3 to the rear of the seat, on either side.
    • One screws are removed, the seat can be easily lifted off the motorcycle.
  5. 1980 -1990 Honda XR80R Carburetor Disassembly: étape 5, image 1 de 2 1980 -1990 Honda XR80R Carburetor Disassembly: étape 5, image 2 de 2
    • Unhook the elastic strap located on the backside of the gas tank.
  6. 1980 -1990 Honda XR80R Carburetor Disassembly: étape 6, image 1 de 3 1980 -1990 Honda XR80R Carburetor Disassembly: étape 6, image 2 de 3 1980 -1990 Honda XR80R Carburetor Disassembly: étape 6, image 3 de 3
    • Remove the gas tank by unscrewing the two 8 mm screws located on both sides, by using the socket wrench.
    • Once screws are removed, the gas tank can be easily taken off the motorcycle.
    • Be careful to keep the gas tank upright in order to prevent the gas spillage.
  7. 1980 -1990 Honda XR80R Carburetor Disassembly: étape 7, image 1 de 3 1980 -1990 Honda XR80R Carburetor Disassembly: étape 7, image 2 de 3 1980 -1990 Honda XR80R Carburetor Disassembly: étape 7, image 3 de 3
    • Loosen screw, located to the left of the carburetor, using Philip head screw driver.
    • The Air intake now can be pulled off from the Carburetor.
  8. 1980 -1990 Honda XR80R Carburetor Disassembly: étape 8, image 1 de 3 1980 -1990 Honda XR80R Carburetor Disassembly: étape 8, image 2 de 3 1980 -1990 Honda XR80R Carburetor Disassembly: étape 8, image 3 de 3
    • Remove the two 8 mm nuts that hold the carburetor to the engine block.
    • The carburetor can now be freely removed from the engine block.
    • Make sure to plug the Carburetor-Engine Block pipe with a clean rag so no damaging dirt can get into the engine.
  9. 1980 -1990 Honda XR80R Carburetor Disassembly: étape 9, image 1 de 3 1980 -1990 Honda XR80R Carburetor Disassembly: étape 9, image 2 de 3 1980 -1990 Honda XR80R Carburetor Disassembly: étape 9, image 3 de 3
    • Unscrew the the top of the carburetor and pull out the wire that is connected to the fuel needle. Set the top aside.
    • If the motorcycle was recently ran, there might be fuel still trapped in the carburetor, so be careful of spillage.
  10. 1980 -1990 Honda XR80R Carburetor Disassembly: étape 10, image 1 de 2 1980 -1990 Honda XR80R Carburetor Disassembly: étape 10, image 2 de 2
    • Using the Phillips head screwdriver, remove the two 10 mm screws located on the underside of the carburetor.
    • Once the screws are removed, the two carburetor halves can then be taken apart.
  11. 1980 -1990 Honda XR80R Carburetor Disassembly: étape 11, image 1 de 2 1980 -1990 Honda XR80R Carburetor Disassembly: étape 11, image 2 de 2
    • On the bottom half of the carburetor, remove the pin that is holding together the fuel bubbler and fuel pin by using needle nose plyers.
  12. 1980 -1990 Honda XR80R Carburetor Disassembly: étape 12, image 1 de 3 1980 -1990 Honda XR80R Carburetor Disassembly: étape 12, image 2 de 3 1980 -1990 Honda XR80R Carburetor Disassembly: étape 12, image 3 de 3
    • In order to remove the Pilot Jets, you will use the Flathead screwdriver to unscrew the two jets from the top.
  13. 1980 -1990 Honda XR80R Carburetor Disassembly: étape 13, image 1 de 1
    • Once fully disassembled, use carburetor cleaner and a rag to fully clean the interior and components of the carburetor, or replace any damaged parts.
2 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 67
30 derniers jours : 256
Total : 4,080
