Aller au contenu principal
1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance
Ce dont vous avez besoin
  1. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance, 1985-1988 Volvo 740 Preparing Car For Work: étape 1, image 1 de 2 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance, 1985-1988 Volvo 740 Preparing Car For Work: étape 1, image 2 de 2
    • Firstly Disconnect battery
    • Always take the negative terminal off first.
    • '''General Tip After disconnecting the battery leave the car for about 10 mins , This lets any residual energy left in the electrical system to dissapate. It is good practise whatever the job
  2. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance, 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: étape 2, image 1 de 2 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance, 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: étape 2, image 2 de 2
    • Unlatch the two clasps, as outlined in the image.
    • Loosen the screw on the metal band, using a flathead screwdriver.
  3. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: étape 3, image 1 de 2 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: étape 3, image 2 de 2
    • Disconnect the electronic sensor from the MAF.
    • Press on the 2 latches, pulling the cable away from the sensor.
  4. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: étape 4, image 1 de 2 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: étape 4, image 2 de 2
    • Disconnect the rubber hose from the MAF.
    • Remove the MAF from the air filter housing.
  5. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: étape 5, image 1 de 1
    • Steps 4-6 are for cleaning only.
    • Spray the MAF cleaner along the direction of travel, shown by the arrow on top of the sensor.
    • (Mass Air Flow sensor Cleaner)
  6. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: étape 6, image 1 de 2 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: étape 6, image 2 de 2
    • Clean the electronic coupling with an electronics cleaner.
  7. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: étape 7, image 1 de 2 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: étape 7, image 2 de 2
    • Inject conducting lubricant into the MAF sensor electronic coupling.
  8. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: étape 8, image 1 de 3 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: étape 8, image 2 de 3 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: étape 8, image 3 de 3
    • Reattach the MAF to the air filter housing and the intake hose.
    • Tighten the screw on the metal band.
    • Latch the clasps on either side of the MAF.
  9. 1985-1988 Volvo 740 Mass Air Flow (MAF) Sensor Maintenance: étape 9, image 1 de 1
    • Reattach the electronic cable to the MAF.
Isaac Nitschke
Membre depuis le 10/11/10
67 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 3-28, Regan Fall 2010 Membre de l'équipe Cal Poly, Team 3-28, Regan Fall 2010
CPSU-REGAN-F10S3G28
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 18
Total : 9,635
