Firstly Disconnect  battery
  • Firstly Disconnect battery
    • Always take the negative terminal off first.
    • '''General Tip After disconnecting the battery leave the car for about 10 mins , This lets any residual energy left in the electrical system to dissapate. It is good practise whatever the job
Ajouter un commentaire
Unlatch the 2 clasps.
  • Unlatch the 2 clasps.
  • Loosen screw on metal band.
  • Disconnect electronic sensor.
  • Press on the 2 latches, pulling the cable away from sensor.
  • Disconnect hose from MAFS.
  • Remove MAFS.
  • Steps 4-6 are for cleaning only.
  • Spray MAFS cleaner along direction of travel, shown by arrow.
  • Clean electronic coupling with electronics cleaner.
  • Inject conducting lubricant into MAFS electronic coupling.
  • Re attach MAFS to air filter housing and intake hose.
  • Tighten screw on metal band.
  • Latch clasps on either side of MAFS.
  • Re attach electronic cable to MAFS.
Isaac Nitschke
Membre depuis le 11/10/2010
61 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 3-28, Regan Fall 2010 Membre de l'équipe Cal Poly, Team 3-28, Regan Fall 2010
CPSU-REGAN-F10S3G28
4 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 29
Total : 7,947
