Introduction
Replacing the spark plugs in your SOHC inline-4 engine may be one of the quickest and easiest ways to provide a nice tune up for your Volvo 240. There is no real need to replace spark plug wires unless one breaks or fails, so see your manufacturer's service manual for recommended replacement intervals. Misfiring or a rough idle may be signs of one or more bad spark plug wires.
There are many aftermarket companies who manufacture spark plug wires that promise to increase performance and fuel economy. However, the most reliable and longest-lasting wires are usually OEM wires from the car's manufacturer. Factory spark plug wires can go hundreds of thousands of miles before requiring replacement.
Outils
Aucun outil requis.
Pièces
To avoid any confusion between which wire goes to which spark plug, replace spark plug wires one at a time. You may want to mark either the old or new wires to remind yourself which ones you've changed.
  • To avoid any confusion between which wire goes to which spark plug, replace spark plug wires one at a time. You may want to mark either the old or new wires to remind yourself which ones you've changed.
  • Disconnect the spark plug wire from the distributor cap by pulling it straight up.
Ajouter un commentaire
Gently twist the spark plug boot back and forth and pull up to remove it from the spark plug.
  • Gently twist the spark plug boot back and forth and pull up to remove it from the spark plug.
  • When installing your new spark plug wires, it's a good idea to apply dielectric grease to the spark plug boots to prevent the electrical connections from being damaged by water or debris.
Install your new spark plug wires in the same manner that you removed the old ones.
2 autre(s) ont terminé cette réparation.
David Hodson
Membre depuis le 13/04/2010
131 048 Réputation
127 tutoriels rédigés
Doing this today. Thanks for the clear, reassuring steps to get it done :)
jeconnol - Réponse
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 20
Total : 2,971
