Introduction
Change the oil in your '90-'95 Toyota 4Runner, with 3.0L V6 engine, to improve engine performance and longevity.
It is typically recommended that you change your vehicle's oil every 3,000 miles for extreme running conditions. However, this number can vary depending on your operating conditions, age of your vehicle, number of miles on your engine and your driving habits. Use of synthetic oils can help reduce engine wear and are advisable for older engines or if your typical driving involves extended periods of stop and go traffic.
Ce dont vous avez besoin
Begin by locating the 14 mm hex oil drain plug. The drain plug is on the driver's side of the truck, facing down and next to the front differential case.
Place an oil drain pan under the oil drain plug.
Use a 14 mm box end wrench or socket wrench to loosen the oil drain plug by turning it counter-clockwise until you can turn it by hand.
Finish removing the oil drain plug by hand to allow the oil to drain.
Clean the drain plug and gasket.
Remove the gasket from the drain plug and inspect both parts for damage. Replace either part if necessary.
I suggest that the gasket be replaced with each drain routine. They are very inexpensive.
Once the draining oil has slowed to a drip, put the oil drain plug back into its hole and turn it clockwise by hand as far as possible.
Continue turning the drain plug clockwise with a 14 mm box end wrench or socket until it is snug.
Wipe off any oil left on the oil pan with a clean rag or towel.
Locate the four 12 mm hex bolts holding the skid plate to the chassis.
Support the skid plate with one hand and use a 12 mm socket wrench to turn the four bolts counter-clockwise until they come out.
Lower the skid plate from the underside of the truck and set it aside.
Turn the oil filter counter-clockwise by hand until it comes off the engine's oil filter threads.
Lower the oil filter out of the engine bay with the threaded end facing up to reduce the amount of oil spilled.
Place the oil filter into the oil drain pan with its open end facing down.
Wipe off the engine's oil filter gasket face with a clean rag or towel.
Place the threaded end of the oil filter onto the engine's oil filter threads, being careful to not get dirt or debris on the filter's gasket.
Turn the filter clockwise by hand until it is snug.
Do not over-tighten your oil filter by using a wrench. Doing so may cause the oil filter seal to leak and will make removing the oil filter very difficult in the future.
Remove the oil drain pan from underneath the truck.
Put the skid plate back into place and support it with one hand. Use your other hand to reinsert the 12 mm bolts, turning them clockwise about two turns.
Use the 12 mm socket wrench to finish turning the bolts clockwise until they are snug.
I grease my 12 mm bolts because they get exposed to water due to their location.
Locate the hood release lever. It is below the left side of the driver's console. Pull it until you hear the hood click.
Go to the front of the truck and locate the hood release latch. It will be under the hood and slightly towards the driver's side of the truck.
Use one hand to lift up on the latch and your other hand to lift the hood open.
Place the hood prop rod into the hole in the top driver's side of the hood marked by an arrow.
Locate the yellow oil dipstick next to the driver's side valve cover and the distributor cap.
Pull out the oil dipstick, wipe it off, place it all the way back into its hole, and remove it again.
Check the oil level on the end of the dipstick. It should be within the cross-hatched area, or slightly above it.
Add oil if the oil level is below the cross hatched area of the dipstick. Place the oil dipstick all the way back in its hole.
Support the hood with one hand and use your other hand to place the hood prop rod back into its holder.
Gently lower the hood until it clicks into the secondary latch.
Press firmly on the edge of the hood until you hear the primary latch engage.
Start the truck and look for leaks underneath it. If there are leaks, shut the truck off and determine if the drain plug or filter need to be tightened.
After running the engine for a few minutes, let it cool down for at least an hour and re-check the oil level. If the oil level is more than a 1/2" above the top hole of the dipstick you will need to drain oil. If the oil level is below the bottom hole of the dipstick you will need to add oil.
Allow 12-24 hours for all the oil to drain out of your old oil filter.
Take your old oil and filter to a recycling facility. Most auto parts stores and repair shops accept these at no charge. In addition, some cities and/or counties have a service where they will collect used oil and filters from your home. For more information, see the American Petroleum Institute's web page on used motor oil collection and recycling.
20 autres ont terminé cette réparation.
9 commentaires
I drained me automadic fliud on my 1995 4 runner 3.0 . i then added one big bottle which ibelieave was 4 quarts. is there now way yo much fluid in my tranny?
No, If You Drained Your Tranny Fluid All The Way It Takes Exactly 10.8 Quarts Of Dexron Tranny Fluid. If You Did Drain It All The Way And Only Added Quarts Back In You Are In Trouble My Friend. -Kevin-
it would not go into gear soi figured it had all drained out. Then my father told me what is in the plan is not all of the automadic tramission fluid.
Thank you for showing me the way
awesome thank you!
Easy to follow and pictures was a plus! Thank you for the step-by-step instructions, I saved money and the learning experience was actual fun!
I watched this specifically to find out if I had to remove the rock guard or not, I did. LOL. I ended up checking out this entire tutorial although I know how to change oil. I must say that if someone can’t change their oil after reading this, well, they should get a bus pass, lol. Great job man.
