Aller au contenu principal
Introduction
Use this guide to replace the driver side airbag in your BMW E36. This procedure was done on a US 1997 M3 with the four spoke steering wheel.
Outils
Pièces
Aucune pièce spécifiée.
    • This step is not necessary, but it made it easier for me to get at the steering column trim mounting screw. Feel free to skip this if you'd like.
    • Remove the two screws securing the upper edge of the knee bolster.
    • Pull the upper edge down to give access to the underside of the steering wheel.
    • Remove the lower steering column trim mounting screw.
    • Remove the lower steering column trim.
    • Make sure that the battery has been disconnected for at least 30 minutes before continuing further to ensure that the airbag light does not come on.
    • Disconnect the orange SRS connector.
    • Completely loosen the two T30 Torx screws behind the steering wheel while supporting the airbag unit from the front.
    • Make sure to support the airbag to prevent it from falling out.
    • Lift the airbag unit up and away from the steering wheel.
    • Disconnect the orange harness connector from the rear of the airbag unit.
    • The airbag should now be free to be removed.
Geoff Wacker
Membre depuis le 30/09/2013
86 836 Réputation
89 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 14
Total : 139
