Aller au contenu principal
1995-2002 Toyota 4Runner Oil and Oil Filter Replacement
Ce dont vous avez besoin
Vidéo d'introduction
  1. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement, Oil and Oil Filter: étape 1, image 1 de 1
    • Make sure the engine oil is hot so it can flow out of the engine easily
    • Either drive the vehicle or run the engine for about 5 minutes before starting the oil change.
  2. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: étape 2, image 1 de 1
    • Begin with removing the steel guard from underneath the vehicle
    • Start by removing the three 12mm socket bolts located at the front of the guard.
  3. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: étape 3, image 1 de 1
    • Remove the two 12mm socket bolts located deep within the front plate.
  4. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: étape 4, image 1 de 1
    • Remove the rear bolts, but the steel guard will not fall off because it has hooks attached to the front frame.
  5. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: étape 5, image 1 de 1
  6. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: étape 6, image 1 de 1
    • With the steel guard removed, locate the engine oil pan and use a 14mm socket wrench to remove the drain plug.
  7. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: étape 7, image 1 de 1
  8. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: étape 8, image 1 de 1
    • Open the filler cap located in the engine bay, which should indicate the required oil type (5W30)
    • Clean the area around the cap and remove it, but place it back loosely to prevent any dirt from falling into the engine.
  9. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: étape 9, image 1 de 1
    • Allow the engine oil to drain for an extended period, such as 30 minutes, to ensure maximum oil removal.
  10. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: étape 10, image 1 de 1
    • While the oil is draining, inspect and clean the splash shield and check for any leaks.
  11. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: étape 11, image 1 de 1
    • Remove the old engine oil filter by reaching it from the front and coming around the lower radiator hose
    • If the filter is not overtightened, you should be able to remove it by hand.
  12. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: étape 12, image 1 de 1
    • Prepare the new engine oil filter by applying a small amount of oil to the rubber gasket.
  13. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: étape 13, image 1 de 1
  14. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: étape 15, image 1 de 1
    • Reinstall the drain plug with its washer and tighten it using the 14mm socket wrench
    • Be careful not to overtighten it, as it could damage the threads on the oil pan
    • The torque for the drain plug is 33 foot-pounds if you want to use a torque wrench.
  15. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: étape 16, image 1 de 1
    • Fill the engine with the recommended 5W-30 engine oil using a funnel
    • Add 4 quarts initially, then gradually add more while checking the dipstick to avoid overfilling.
  16. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: étape 17, image 1 de 1
    • Fill the engine with a total of 5.5 US quarts of engine oil, as specified in the manual for an oil change with filter replacement.
  17. 1995-2002 Toyota 4Runner Oil and Oil Filter Replacement: étape 18, image 1 de 1
    • Reinstall the steel guard using the 12mm socket wrench, making sure to apply anti-seize to the bolts for easy removal in the future.
eCuration
Membre depuis le 05/19/17
378 307 Réputation
236 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
140 membres
18 076 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 14
30 derniers jours : 120
Total : 10,119
