Introduction
Here you will learn how to remove the wood panel from the center dash unit. After doing this guide you will be free to get to the center dash and stereo/cd/cassete players.
Pièces
Aucune pièce nécessaire.
  1. Using a panel tool or long flat head screwdriver, pry the wood grain trim off and release the clips.  Be careful on the thin sections below the head unit as to not snap the trim.
    • Using a panel tool or long flat head screwdriver, pry the wood grain trim off and release the clips. Be careful on the thin sections below the head unit as to not snap the trim.
  2. Detach the wiring harness from the back of the air conditioning control unit by pushing down on the top middle tab and pulling apart using a screwdriver for leverage if necessary.
    • Detach the wiring harness from the back of the air conditioning control unit by pushing down on the top middle tab and pulling apart using a screwdriver for leverage if necessary.
2 autre(s) ont terminé cette réparation.
Brayden
Membre depuis le 05/10/2012
13 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 18-42, Regan Fall 2012 Membre de l'équipe Cal Poly, Team 18-42, Regan Fall 2012
CPSU-REGAN-F12S18G42
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 2,047
