Aller au contenu principal
Pour réparer ensemble - Je crée un compte
1996-1998 Acura TL Front Speaker Replacement
Ce dont vous avez besoin
    1. 1996-1998 Acura TL Front Speaker Replacement, Front Door Panel: étape 1, image 1 de 1
      • Roll the window down all the way and open the door as far as it can go.
      • Locate the screw cap in the bottom of the armrest cavity.
      • Remove the cap by finger or pry it off with a flathead screwdriver if necessary to reveal the screws beneath.
      Demander à FixBot
      Ajouter un commentaire
    2. 1996-1998 Acura TL Front Speaker Replacement: étape 2, image 1 de 1
      • Locate the screw cap inside of the door opening cavity.
      • Remove the cap by finger or pry it off if necessary to reveal the screws beneath.
      Demander à FixBot
    3. 1996-1998 Acura TL Front Speaker Replacement: étape 3, image 1 de 1
      • Unscrew both of the screws that are now uncovered.
      • One of the screws is in the armrest cavity, the other is in the back of the door handle's cavity.
      Demander à FixBot
    4. 1996-1998 Acura TL Front Speaker Replacement: étape 4, image 1 de 1
      • Wtth the screw gone, slide the entire wooden armrest unit to the right (away from the car).
      • Once the armrest can not go any further lift straight up out of its spot.
      • Before lifting too far reach under and remove the wiring from the wire harness by pinching down on the white tab and pulling straight back.
      • The window control is now removed and you can set the wooden door panel unit aside.
      Demander à FixBot
    5. 1996-1998 Acura TL Front Speaker Replacement: étape 5, image 1 de 1
      • Similarly wiggle the door handle frame to its right to remove.
      • You must move the handle out of the way as if opening the door to get the frame around it and out of the door.
      • Just like last time reach behind, pinch the tab and pull straight back to remove the circuitry for the door lock.
      • Once the entire frame is removed from the door and the circuitry, place it to the side with the armrest part.
      Demander à FixBot
    6. 1996-1998 Acura TL Front Speaker Replacement: étape 6, image 1 de 1
      • Pry the inside door frame off of the actual metal exterior door.
      • Use a flathead screw driver for leverage to pop all of the plugs off. Do not be afraid to use force as they are just snaps that will not break and will go back into place perfectly.
      • The locations of the plugs have been circled for your convenience. Although applying leverage at all points around the sides and bottom will pop them off just as easily and safely.
      Demander à FixBot
    7. 1996-1998 Acura TL Front Speaker Replacement: étape 7, image 1 de 1
      • Lift the door panel straight up and off. The metal strip on the top of the door panel will come with the panel as you remove it from the door.
      • It should slide off quite easily if all the plugs are unsnapped. Do not pull past the tension of the circuitry, as the wires are still plugged into the harness.
      Demander à FixBot
    8. 1996-1998 Acura TL Front Speaker Replacement: étape 8, image 1 de 1
      • Unplug the harness to the interior door light in the bottom right corner (farthest from the car)
      • Simply push down on the grey tab and pull straight out.
      Demander à FixBot
    9. 1996-1998 Acura TL Front Speaker Replacement: étape 9, image 1 de 1
      • Remove the interior door panel completely, exposing the inside of the door and the front speaker.
      Demander à FixBot
    1. 1996-1998 Acura TL Front Speaker Replacement, Front Speaker: étape 10, image 1 de 1
      • Remove the four screws holding the front door speaker in.
      Demander à FixBot
    2. 1996-1998 Acura TL Front Speaker Replacement: étape 11, image 1 de 1
      • Pull the speaker out.
      • Disconnect the wiring by simply sliding the clamp off that connects it to the rear of the speaker.
      Demander à FixBot
2 autres ont terminé cette réparation.
Brayden
Membre depuis le 10/05/12
16 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 18-42, Regan Fall 2012 Membre de l'équipe Cal Poly, Team 18-42, Regan Fall 2012
CPSU-REGAN-F12S18G42
4 membres
21 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 37
Total : 3,580
