Introduction
Use this guide to replace a head light in your '98-'02 Honda Accord.
Pull on the hood release lever just inside the passenger door to pop the hood.
Locate the hood release latch under the hood. Use one hand to press up on the latch while you lift the hood.
Insert the hood prop rod into the hole in the hood marked with an arrow.
Locate the head light bulbs and connectors directly behind the headlights and on either side of the engine bay.
Detach the head light connectors by pushing on the lever on the top of the connector and pulling it straight down.
The passenger side low beam bulb was extremely difficult to remove, owing to very little space to work in. Then I realized that the air intake could be rotated and pulled out. It was easier than removing the battery. After that it was very simple. I found it easier to first unscrew the bulb assembly, and then detach the connectors.
Thanks!
never seen or found a lever to push on top of connector, tho I do see it but it won’t pull of easy….a better picture or a close up and different description may help, I know to twist the back part of the bulb, I’ve done it before, but is giving me difficulty now, bulb won’t come out and harness won’t come off bulb either….very frustrating. 2002 accord
Turn the head light bulb counterclockwise and pull it straight back to remove it.
27 autres ont terminé cette réparation.
13 commentaires
I change both bulbs and still high beam don't work what else can be wrong
Nobody can replace the headlight for my 1999 Honda Accord (low beam). Everyone says the 9006 is supposed to fit the socket. The socket is fine; the connector for the new bulb is covered by a plastic sheath, which the old bulb doesn't have. Should I go to a dealer for this part?
Did you end up with a solution I'm having a similar issue
Bulb was out on left side 2001 accord. Decided to replace both bulbs but the receptacle on the right was different. It was set up to receive 2 small tabs instead of the 1 tab on the left side which received the 9006 bulb perfectly. I have never seen this before. Has anyone else had this happen?
Well The passenger side headlight has the Coolant tank and battery and other things in the way that make it nearly impossible to reach. Then, the light socket doesn’t twist out very easily..in fact I can’t even budge it…needs some kind of release fluid or something. It won’t turn at all. Any suggestions would help.
passenger side hood release? really,,,lol
Dear all ,
I'm having Honda Accord 2001 automatic, driving seat switch seams not working , seat is completely in front of the starting it's very difficult to seat and drive kindly give me some tricks to solve this issue,
Thanks
zabihussaini@gmail.com
I just bought a 2002 Honda Accord Sedan and cannot find where the hood support rod goes when your ready to close the hood. A picture would be great!
Como puedo resolver que las luces permanentes traseras y la pizarra no encienden todas las demás prenden
Yoan - Réponse
También se prenden solas todas las luces
Yoan - Réponse
