Aller au contenu principal
1999-2011 Ford Ranger Tail Light Bulb Replacement
Ce dont vous avez besoin
  1. 1999-2011 Ford Ranger Tail Light Bulb Replacement, Tail Light Bulb: étape 1, image 1 de 3 1999-2011 Ford Ranger Tail Light Bulb Replacement, Tail Light Bulb: étape 1, image 2 de 3 1999-2011 Ford Ranger Tail Light Bulb Replacement, Tail Light Bulb: étape 1, image 3 de 3
    • Pull the tailgate latch and lower the tailgate down so that it is open.
  2. 1999-2011 Ford Ranger Tail Light Bulb Replacement: étape 2, image 1 de 3 1999-2011 Ford Ranger Tail Light Bulb Replacement: étape 2, image 2 de 3 1999-2011 Ford Ranger Tail Light Bulb Replacement: étape 2, image 3 de 3
    • Remove the two 19mm Phillips #1 screws on the taillight housing that face the inside of the bed.
    • Remove the two 38mm Phillips #1 screws on the taillight housing that face the outside of the truck.
  3. 1999-2011 Ford Ranger Tail Light Bulb Replacement: étape 3, image 1 de 3 1999-2011 Ford Ranger Tail Light Bulb Replacement: étape 3, image 2 de 3 1999-2011 Ford Ranger Tail Light Bulb Replacement: étape 3, image 3 de 3
    • Pull the taillight housing down from the truck so that the wires and plugs are exposed.
  4. 1999-2011 Ford Ranger Tail Light Bulb Replacement: étape 4, image 1 de 1
    • Remove any dirt or dust around the taillight plug so that nothing falls into the lens.
  5. 1999-2011 Ford Ranger Tail Light Bulb Replacement: étape 5, image 1 de 3 1999-2011 Ford Ranger Tail Light Bulb Replacement: étape 5, image 2 de 3 1999-2011 Ford Ranger Tail Light Bulb Replacement: étape 5, image 3 de 3
    • Loosen and remove the taillight plug so that the bulb is exposed.
  6. 1999-2011 Ford Ranger Tail Light Bulb Replacement: étape 6, image 1 de 3 1999-2011 Ford Ranger Tail Light Bulb Replacement: étape 6, image 2 de 3 1999-2011 Ford Ranger Tail Light Bulb Replacement: étape 6, image 3 de 3
    • Remove the old or damaged bulb.
    • Insert the new bulb into the exposed plug and then insert the plug back into the taillight housing and tighten.
2 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 37
30 derniers jours : 126
Total : 6,632
