Aller au contenu principal
1999-2004 Honda Odyssey Coolant and Washer Fluid Check
Ce dont vous avez besoin
  1. 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Coolant: étape 1, image 1 de 3 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Coolant: étape 1, image 2 de 3 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Coolant: étape 1, image 3 de 3
    • Turn off the car and pull the latch to release the hood.
  2. 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Coolant: étape 2, image 1 de 3 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Coolant: étape 2, image 2 de 3 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Coolant: étape 2, image 3 de 3
    • Pull the hood release upwards to open the hood and use the prop rod to keep it open.
  3. 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Coolant: étape 3, image 1 de 1
    • Locate the coolant container behind the passenger side headlight.
  4. 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Coolant: étape 4, image 1 de 1
    • Check the fluid level is in between the max and the min mark on the coolant container. If it is at the max, proceed to step 7.
    • If the fluid level is below the max, you need to fill it up, continue to step 4.
    • If the coolant tank is empty, continue to step 4
    • Hot coolant is pressurized, make sure the vehicle is turned off for 15 minutes.
  5. 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Coolant: étape 5, image 1 de 1
    • Loosen the coolant cap a little, then step back while the pressure releases. Now, completely remove the coolant cap.
    • Wait for any built-in pressure to release before completely removing the cap, pressurized coolant is hot and can scald.
    • Place a funnel on top of the coolant container opening
  6. 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Coolant: étape 6, image 1 de 1
    • Use caution while handling coolant fluid. The product is flammable.
    • Pour the Prestone coolant liquid into the container until the liquid reaches the “max” line.
    • If you have a funnel. Place the funnel into the top of the container.
    • Pour the coolant liquid into the funnel until the liquid reaches the “max” line.
  7. 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Coolant: étape 7, image 1 de 1
    • Firmly place the cap back onto the container.
  8. 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Coolant: étape 8, image 1 de 1
    • Close the hood.
    • If doing multiple checks closing the hood is not required.
  9. 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Washer: étape 9, image 1 de 1
    • Locate the Washer container.
  10. 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Washer: étape 10, image 1 de 2 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Washer: étape 10, image 2 de 2
    • Open the washer fluid container and completely remove the cap.
  11. 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Washer: étape 11, image 1 de 1
    • Pour the Prestone washer liquid into the container until the liquid reaches the top of the container.
  12. 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Washer: étape 12, image 1 de 1
    • Place the cap back onto the container.
  13. 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Washer: étape 13, image 1 de 1
    • Close the hood.
Ligne d'arrivée
TheGeorgeJr672
Membre depuis le 07/02/21
247 Réputation
1 tutoriel rédigé
Équipe
University of Memphis, Group 4, Summer 2021 Membre de l'équipe University of Memphis, Group 4, Summer 2021
Community
2 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 14
Total : 2,814
