Introduction
This is to show how to replace the lift supports of the rear hatch. The hatch is quite heavy so use some sort of support or an assistant when changing the supports. the left and right strut are identically mounted. All steps apply to either side
Outils
Pièces
  1. Open the tail gate and either prop it up or use an assistant to hold it. The tail gate is heavy and will fall if not properly supported. Right tailgate lift support strut
    • Open the tail gate and either prop it up or use an assistant to hold it.
    • The tail gate is heavy and will fall if not properly supported.
    • Right tailgate lift support strut
    • Left tailgate lift support strut
  2. %Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  3. The struts are fastened with T-40 Torx head bolts. Using a t-40 Torx driver to loosen the bolt The bolt does not remove from the strut. It is pressed in and will be replaced with the new strut
    • The struts are fastened with T-40 Torx head bolts.
    • Using a t-40 Torx driver to loosen the bolt
    • The bolt does not remove from the strut. It is pressed in and will be replaced with the new strut
  4. Completely loosen  the bolt securing the strut to the top of the tailgate with a T-40 driver. Replace the worn strut with a new one. On this vehicle both struts were replaced. This stopped the sagging of the tailgate
    • Completely loosen the bolt securing the strut to the top of the tailgate with a T-40 driver.
    • Replace the worn strut with a new one.
    • On this vehicle both struts were replaced. This stopped the sagging of the tailgate
To reassemble your Jeep, follow these instructions in reverse order.
8 autre(s) ont terminé cette réparation.
oldturkey03
Membre depuis le 29/09/2010
559 072 Réputation
101 tutoriels rédigés
Équipe
OTS Membre de l'équipe OTS
Business
1 membre
123 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 10
7 derniers jours : 36
30 derniers jours : 150
Total : 5,451
