Aller au contenu principal
1999-2001 Mazda Miata (MX-5) Door Speaker Replacement
Ce dont vous avez besoin
  1. 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement, Door Speaker: étape 1, image 1 de 2 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement, Door Speaker: étape 1, image 2 de 2
    • The battery is in the right side of the rear cargo compartment. It can be found by moving the carpet and wood cover.
    • With a 10mm wrench, remove the positive battery terminal.
    • Do not let any metal in contact with the positive battery terminal contact any other metal item. This might make sparks.
  2. 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: étape 2, image 1 de 3 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: étape 2, image 2 de 3 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: étape 2, image 3 de 3
    • Remove the three trim panel retainer clips.
    • Old clips might break easily. Be extra careful when removing them or get spares.
  3. 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: étape 3, image 1 de 3 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: étape 3, image 2 de 3 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: étape 3, image 3 de 3
    • Remove the three screws that hold the door panel in place.
    • These screws are all different, so keep note of where they all go. The short screw goes in the door latch; the long screws go in the door handle.
  4. 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: étape 4, image 1 de 2 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: étape 4, image 2 de 2
    • Remove the cover around the door latch by pulling the handle and rotating the cover.
  5. 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: étape 5, image 1 de 2 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: étape 5, image 2 de 2
    • Remove the door panel by pulling the bottom out and lifting up.
  6. 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: étape 6, image 1 de 3 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: étape 6, image 2 de 3 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: étape 6, image 3 de 3
    • Remove the four screws holding the plastic speaker mount.
    • As you remove the screws, don't let the speaker fall out and pull the wire.
  7. 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: étape 7, image 1 de 3 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: étape 7, image 2 de 3 1999-2001 Mazda Miata (MX-5) Door Speaker Replacement: étape 7, image 3 de 3
    • Detach the connector that powers the speaker by pressing down on the top latch and gently pulling.
    • A small screwdriver might help with the latch but be careful. Old plastic can be brittle.
Nathan J
Membre depuis le 02/20/24
145 Réputation
1 tutoriel rédigé
Équipe
University of Arizona, Team 2-1, Cools Stephens Spring 2024 Membre de l'équipe University of Arizona, Team 2-1, Cools Stephens Spring 2024
ARIZONA-COOLS STEPHENS-S24S2G1
2 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 11
30 derniers jours : 45
Total : 118
