Aller au contenu principal
1999 GMC Suburban Brake Light Replacement
Ce dont vous avez besoin
  1. 1999 GMC Suburban Brake Light Replacement, Brake Light: étape 1, image 1 de 3 1999 GMC Suburban Brake Light Replacement, Brake Light: étape 1, image 2 de 3 1999 GMC Suburban Brake Light Replacement, Brake Light: étape 1, image 3 de 3
    • Before you begin, turn off your car, put it in park, and engage the emergency brake.
    • Select the side of the car you would like to work on first.
    • Open the trunk doors.
  2. 1999 GMC Suburban Brake Light Replacement: étape 2, image 1 de 3 1999 GMC Suburban Brake Light Replacement: étape 2, image 2 de 3 1999 GMC Suburban Brake Light Replacement: étape 2, image 3 de 3
    • These two holes have screws inside of them, so unscrew them to get the brake light out.
    • The screws that will be removed for this step are "Round washer head pozi-drive tapping screw tail lamp assembly M4.2-1.41 x 20mm".
  3. 1999 GMC Suburban Brake Light Replacement: étape 3, image 1 de 3 1999 GMC Suburban Brake Light Replacement: étape 3, image 2 de 3 1999 GMC Suburban Brake Light Replacement: étape 3, image 3 de 3
    • When removing the tail light there are little hooks with holes that are used to hold them in place as shown in the first photo.
    • The tail should already be loose from the previous step so pull it out slowly by turning it on its side and then pulling forward.
    • Use the 7 mm socket to unscrew the two bolts securing the brake light housing to the tail light assembly.
    • The screws in this step are "Rexka 30pcs M4.2-1.41 x 20mm".
  4. 1999 GMC Suburban Brake Light Replacement: étape 4, image 1 de 2 1999 GMC Suburban Brake Light Replacement: étape 4, image 2 de 2
    • After taking off the screws, take the brake lights out and find which light isn't working by stepping on the brake.
  5. 1999 GMC Suburban Brake Light Replacement: étape 5, image 1 de 1
    • With the actual light, unplug them by pulling them out but not with too much force.
    • Plug the new light bulb(s) in place of the ones that don't work.
    • Please be careful with how you remove the bulbs because they are made of glass.
  6. 1999 GMC Suburban Brake Light Replacement: étape 6, image 1 de 2 1999 GMC Suburban Brake Light Replacement: étape 6, image 2 de 2
    • Now put everything back together and put all the screws back on.
    • The steps are the same on both sides and is a fairly simple and fast process.
Marcos Shipley
Membre depuis le 10/25/23
133 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 12-10, Ribeiro Fall 2023 Membre de l'équipe CSU Los Angeles, Team 12-10, Ribeiro Fall 2023
CSULA-RIBEIRO-F23S12G10
1 membre
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 27
Total : 315
