Aller au contenu principal
2 slice Dualit toaster Disassembly
  1. 2 slice Dualit toaster Disassembly, Removing rubber feet: étape 1, image 1 de 1
    • 4 x rubber feet
    • 5 x metal screws
    • Remove the rubber feet and screws with a phillips head screw driver.
  2. 2 slice Dualit toaster Disassembly, Removing bottom plate: étape 2, image 1 de 1
    • 1 x Matte Aluminium Bottom Plate
    • After removing the Feet and Screws the Bottom plate simply lifts off.
  3. 2 slice Dualit toaster Disassembly, Removing crumb tray: étape 3, image 1 de 1
    • simply slide out the aluminium crumb tray
  4. 2 slice Dualit toaster Disassembly, Removing main polished casing: étape 4, image 1 de 1
    • 1 x Stainless Steel main casing
    • 6 x Phillips Head Metal Screws
    • Remove screws from main body of toaster and ply the metal casing off with your hands from either side.
  5. 2 slice Dualit toaster Disassembly, Removing end cap: étape 5, image 1 de 1
    • 1 x Casted Aluminium End Cap from the left hand side of the toaster
    • After removing the screws from part 4 this end cap will just pull off with a gentle tug.
  6. 2 slice Dualit toaster Disassembly: étape 6, image 1 de 1
    • 1 x Cast Aluminium timer casing
    • To remove the other side casing of the toaster you must first disconnect the electrical cords from the elements
    • Once all the cords are unplugged the casing will simply pull off the same way as the other side casing was removed
  7. 2 slice Dualit toaster Disassembly: étape 7, image 1 de 1
    • 2 x Nut
    • 2 x Bolt
    • 2 x Washers
    • 1 x Galvanised Steel elements fastener plate
    • To remove the element fastener plate us the pliers to prevent the nut from twisting whilst unscrewing the bolt with the PH screwdriver.
    • Once unscrewed the plate should easily pull away.
  8. 2 slice Dualit toaster Disassembly: étape 8, image 1 de 1
    • 1 x Lever mechanism
    • 1 x Spring
    • 1 x Washer
    • 1 x Plastic lever handle
    • 2 x Aluminium fastening plates
    • To remove the Lever mechanism you must first unscrew and remove the black plastic handle.
    • After this the two fastening plate will can be removed. The screws holding these in place have already been removed in the previous step.
    • The lever mechanism can now be removed from the toaster. This may take some manoeuvring for the mechanism to slide out.
  9. 2 slice Dualit toaster Disassembly: étape 9, image 1 de 1
    • 3 x heating elements
    • 2 x Brass dividers
    • 2 x Copper wires
    • 2 x Bolts
    • 6 x Washers
    • 4 x Nuts
    • To remove the heating elements unscrew the bolts with the PH screwdriver whilst holding the nuts with the pliers
    • Once unscrewed the wires and copper dividers are able to be removed. Then simple slide out the heating elements. The elements need to be replaced in the same slots they came from so label them.
  10. 2 slice Dualit toaster Disassembly: étape 10, image 1 de 1
    • 2x aluminium internal side panels.
    • These thin aluminium plates will then be removed from the main body assembly. These sheets help reduce heat admitted from the toaster upon use.
  11. 2 slice Dualit toaster Disassembly: étape 11, image 1 de 1
    • 3x bent stainless steel excursions.
    • These parts are holding the bread in a perfect position in relation to the elements. They are then to be popped out of place from the main body assembly.
  12. 2 slice Dualit toaster Disassembly: étape 12, image 1 de 1
    • This is the final sub assemble or main body you are left with. This body is the queen bee of all the above parts.
2 autres ont terminé cette réparation.
hugh johnston
Membre depuis le 04/23/20
265 Réputation
1 tutoriel rédigé
5 Guide Comments
What size are the screws used to secure the outer casing?
Roger Houghton - Réponse
On my model A2BR/87 they’re #2 Pozidriv screws.
You can tell the difference between Phillips and Pozidriv screws because the latter have very small lines etched between the four arms of the cross on the screw head. Phillips screws (and screwdriver) should work, but if you use them too many times on a Pozidriv screw then they'll eventually wreck them. On the other hand, you can't use a Pozidriv screwdriver at all on a Phillips screw so check to see which kind of screw you have.
FWIW, I had to get Pozidriv screwdrivers to work on my Saeco espresso machine.
Colin Macdonald - Réponse
If you just need to replace the Dualit 2 slice toaster, Lifter Assembly what is involved in doing that. Surely you don't have to remove all the sides etc. What would you recommend to replace this one element?
Charles Tremewen - Réponse
Is the Cast Aluminum Timer Casing one part that is available? My toaster is an American Dualit. The timer mechanism doesn't work. I would like to replace just this part. Can you help me remove it?
Bernie H - Réponse
I have a 2 slices 2021 Dualit Domus DLT22 toaster that is dead and probably needs a new timer. Dualit say they no longer supply spare parts for that model. Do you know where I can source a compatible replacement part?
Martin McIntosh - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 27
30 derniers jours : 158
Total : 5,913
