Introduction
Regular maintenance on a 2000-2006 (E46) BMW M3 is very important, but going to a dealership or certified technician can be expensive. So why not do some of it yourself? Replacing the air filter in the engine, for instance, is a simple, not too invasive, and low-risk job for anyone looking to save the $100+ that a dealer might charge to do the job.
Note: This guide may not apply to the installation of an aftermarket air filter.
Ce dont vous avez besoin
With the vehicle turned off, open the hood of the car by pulling the hood release lever in the driver's side foot well.
Walk around to the front of the car and pull upward on the latch protruding from the grill.
Identify the two plastic clips on the left side of the box. These clips consist of small plastic hooks on the lid hooked into square holes attached to the base.
To remove these, press the left side of the lid down and pull up slightly on the right side. While doing this, gently slide the lid to the right.
If done correctly, you should now be able to see the rubber gasket of the air filter (most likely it will be bright orange).
Gently lift the air box lid up on the right side enough to remove the air filter (should be about 3-4 inches).
Lift the air filter up by the bright orange gasket. If you have trouble prying it up, you can gently use a flat head screwdriver for help.
Slide the air filter out of the box.
4 autres ont terminé cette réparation.
