Aller au contenu principal
2001-2007 Ford Escape Headlight Replacement
Ce dont vous avez besoin
  1. 2001-2007 Ford Escape Headlight Replacement, Headlight: étape 1, image 1 de 1
    • Release the hood latch located under the dashboard on the driver side of the vehicle.
    • You will hear a pop sound once the hood is properly detached.
  2. 2001-2007 Ford Escape Headlight Replacement: étape 2, image 1 de 1
    • Push in on the sides of the bulb plug and pull directly out. It may take a bit of wiggling and effort to remove the plug.
  3. 2001-2007 Ford Escape Headlight Replacement: étape 3, image 1 de 2 2001-2007 Ford Escape Headlight Replacement: étape 3, image 2 de 2
    • Remove the rubber boot surrounding the housing. It will peel off when pulling the tabs to the side.
    • You may need a pry tool to remove the rubber boot. Always use an appropriate pry tool for the job.
  4. 2001-2007 Ford Escape Headlight Replacement: étape 4, image 1 de 2 2001-2007 Ford Escape Headlight Replacement: étape 4, image 2 de 2
    • Unlatch the bulb retention clip by pushing in on the two circle pins and pushing them apart.
    • They're similar to springs and will push away from each other once released.
  5. 2001-2007 Ford Escape Headlight Replacement: étape 5, image 1 de 1
    • Remove the bulb by pulling it directly out of the housing. Once the bar is out of the way, the bulb isn't held onto by any remaining parts.
    • Be careful when removing bulbs to not scratch or damage the glass portion. Shattered glass is potentially harmful.
  6. 2001-2007 Ford Escape Headlight Replacement: étape 6, image 1 de 1
    • Line the new bulb along the housing and set it in place. Clip the bar back down into it's original position from step 4 to secure it in place.
    • Be careful when handling headlight bulbs. Do not get any fingerprints on the glass of the bulb. Fingerprints can heat up when the light is turned on and cause the bulb to fail. Always grab the bulb by the end.
  7. 2001-2007 Ford Escape Headlight Replacement: étape 7, image 1 de 2 2001-2007 Ford Escape Headlight Replacement: étape 7, image 2 de 2
    • Reverse steps 2 and 3 to finish installing the new bulb. These steps are mirrored on the driver side of the vehicle.
To reassemble your device, follow these instructions in reverse order. Both the driver side and passenger side follow the same procedure.
John Morrison
Membre depuis le 03/23/21
169 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S1-G11, O'Connell Spring 2021 Membre de l'équipe UMass Dartmouth, Team S1-G11, O'Connell Spring 2021
UMASSD-O'CONNELL-S21S1G11
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 16
30 derniers jours : 52
Total : 2,739
