Introduction
Replacing the rear differential on a 2001 Audi TT
Ce dont vous avez besoin
Lets get started! A car lift is recommended for this task but it can be done with just a jack if required.
The exhaust is held in with two bolts at the middle of car underneath . It the hangs from 4 rubber mount wich can be unhooked with a small screw driver and some leverage.
Be careful not to tear the rubber mounts.
Sorry for missing images they were never taken during the exhaust removal.
Dismount the ground strap located to the left of the driver side rear axle hub.
Removing the passenger side gas tank shield will make step 7 easier.
Remove the 4 bolts on both sides that hold the rear differential in the car.
Be sure to have some sort of jack or object to hold the rear differential into the car as you continue to work.
