Aller au contenu principal
2002-2009 Trailblazer Tail Light Bulb Replacement
Ce dont vous avez besoin
  1. 2002-2009 Trailblazer Tail Light Bulb Replacement, Tail Light Bulb: étape 1, image 1 de 3 2002-2009 Trailblazer Tail Light Bulb Replacement, Tail Light Bulb: étape 1, image 2 de 3 2002-2009 Trailblazer Tail Light Bulb Replacement, Tail Light Bulb: étape 1, image 3 de 3
    • Open up the trunk.
    • Remove the two screws next to the tail light using a Phillips #0 screwdriver.
  2. 2002-2009 Trailblazer Tail Light Bulb Replacement: étape 2, image 1 de 3 2002-2009 Trailblazer Tail Light Bulb Replacement: étape 2, image 2 de 3 2002-2009 Trailblazer Tail Light Bulb Replacement: étape 2, image 3 de 3
    • Position yourself with the tail light in front of you. Pull the tail light towards you.
    • Be careful because the headlight is connected to the car.
    • Apply pressure on the clip and pull it out to disconnect the tail light from the car.
  3. 2002-2009 Trailblazer Tail Light Bulb Replacement: étape 3, image 1 de 3 2002-2009 Trailblazer Tail Light Bulb Replacement: étape 3, image 2 de 3 2002-2009 Trailblazer Tail Light Bulb Replacement: étape 3, image 3 de 3
    • Remove three screws that hold the lights in place, one on the top and two at the bottom using a Phillips #0 screwdriver.
  4. 2002-2009 Trailblazer Tail Light Bulb Replacement: étape 4, image 1 de 3 2002-2009 Trailblazer Tail Light Bulb Replacement: étape 4, image 2 de 3 2002-2009 Trailblazer Tail Light Bulb Replacement: étape 4, image 3 de 3
    • Pull up to expose the three lightbulbs.
    • From here, choose the bulb that needs to be replaced. In this guide, I will be replacing the stoplight.
    • Use your fingers to pinch the sides of the lightbulb.
    • Pull up to remove the bulb.
  5. 2002-2009 Trailblazer Tail Light Bulb Replacement: étape 5, image 1 de 3 2002-2009 Trailblazer Tail Light Bulb Replacement: étape 5, image 2 de 3 2002-2009 Trailblazer Tail Light Bulb Replacement: étape 5, image 3 de 3
    • Open the package of lightbulbs and take one out to use.
    • Apply a bit of pressure on the sides of the light bulb, and push it down into the socket.
  6. 2002-2009 Trailblazer Tail Light Bulb Replacement: étape 6, image 1 de 3 2002-2009 Trailblazer Tail Light Bulb Replacement: étape 6, image 2 de 3 2002-2009 Trailblazer Tail Light Bulb Replacement: étape 6, image 3 de 3
    • Reconnect the lights to the car.
    • Turn the car on to see if the lights are working correctly.
2 autres ont terminé cette réparation.
Carlos Diaz
Membre depuis le 03/19/22
160 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team G-33, Briggs Spring 2022 Membre de l'équipe CSU Los Angeles, Team G-33, Briggs Spring 2022
CSULA-BRIGGS-S22SGG33
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 19
30 derniers jours : 139
Total : 3,504
