Aller au contenu principal
2002-2006 Toyota Camry Key Fob Battery Replacement
Ce dont vous avez besoin
  1. 2002-2006 Toyota Camry Key Fob Battery Replacement, Key Fob Battery: étape 1, image 1 de 2 2002-2006 Toyota Camry Key Fob Battery Replacement, Key Fob Battery: étape 1, image 2 de 2
    • Purchase a new lithium coin battery. You can find it at your local hardware store.
    • The battery has a "+" positive side (textured surface) and a "–" negative side (smooth surface).
  2. 2002-2006 Toyota Camry Key Fob Battery Replacement: étape 2, image 1 de 1
    • Use your hands or a spudger to separate the key fob into two pieces.
  3. 2002-2006 Toyota Camry Key Fob Battery Replacement: étape 3, image 1 de 1
    • Identify which part of the FOB holds the battery.
    • You will not need the other part of the fob until the end.
  4. 2002-2006 Toyota Camry Key Fob Battery Replacement: étape 4, image 1 de 2 2002-2006 Toyota Camry Key Fob Battery Replacement: étape 4, image 2 de 2
    • Remove the battery from the fob by releasing it from the holder using a spudger or by hand.
    • Be careful that you don't break the contacts when removing the battery.
  5. 2002-2006 Toyota Camry Key Fob Battery Replacement: étape 5, image 1 de 1
    • Insert the new battery by pushing it down.
  6. 2002-2006 Toyota Camry Key Fob Battery Replacement: étape 6, image 1 de 1
    • Reassemble the fob, using your hands to press the two parts together.
Salman Abu Mazen
Membre depuis le 09/27/21
140 Réputation
1 tutoriel rédigé
Équipe
UM-Willis-F21S51G7 Membre de l'équipe UM-Willis-F21S51G7
Community
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 57
30 derniers jours : 250
Total : 5,627
