Aller au contenu principal
2002 Nissan Altima Hubcap Replacement
Ce dont vous avez besoin
  1. 2002 Nissan Altima Hubcap Replacement, Hubcap: étape 1, image 1 de 3 2002 Nissan Altima Hubcap Replacement, Hubcap: étape 1, image 2 de 3 2002 Nissan Altima Hubcap Replacement, Hubcap: étape 1, image 3 de 3
    • Attach the retention ring to your new hubcap, aligning the divot in the ring with the tire-valve cutout.
    • Be sure to click the ring in each clip around the hubcap.
  2. 2002 Nissan Altima Hubcap Replacement: étape 2, image 1 de 1
    • Use a wide tipped removal tool to align the wedge inside the hubcap.
    • You may be able to remove the hubcap with your hands if you grab and pull. Be careful, though, to not injure yourself.
  3. 2002 Nissan Altima Hubcap Replacement: étape 3, image 1 de 1
    • Gently push on the solid parts of the hubcap until they pop out of the tire.
  4. 2002 Nissan Altima Hubcap Replacement: étape 4, image 1 de 2 2002 Nissan Altima Hubcap Replacement: étape 4, image 2 de 2
    • Align the replacement hubcap with the tire valve.
    • There should be a cutout in the hubcap to specifically fit around the tire valve.
  5. 2002 Nissan Altima Hubcap Replacement: étape 5, image 1 de 2 2002 Nissan Altima Hubcap Replacement: étape 5, image 2 de 2
    • Keeping alignment, hold the center of the hubcap and forcefully push in all the sides of the inner ring until it secures in place.
  6. 2002 Nissan Altima Hubcap Replacement: étape 6, image 1 de 1
    • Repeat steps 1-5 for other three tires.
Ligne d'arrivée
Bre Sanders
Membre depuis le 04/26/24
133 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team 2-6, Whithaus Spring 2024 Membre de l'équipe UC Davis, Team 2-6, Whithaus Spring 2024
UCD-WHITHAUS-S24S2G6
2 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 7
Total : 80
