Aller au contenu principal
2002 Toyota Tacoma Headlight Bulb Replacement
Ce dont vous avez besoin
  1. 2002 Toyota Tacoma Headlight Bulb Replacement, Headlight Bulb: étape 1, image 1 de 1
    • Pull the lever under the steering wheel.
  2. 2002 Toyota Tacoma Headlight Bulb Replacement: étape 2, image 1 de 2 2002 Toyota Tacoma Headlight Bulb Replacement: étape 2, image 2 de 2
    • Pull up on the lever under the hood.
    • At the same time, lift the hood of the car.
  3. 2002 Toyota Tacoma Headlight Bulb Replacement: étape 3, image 1 de 2 2002 Toyota Tacoma Headlight Bulb Replacement: étape 3, image 2 de 2
    • Remove the metal rod.
    • Insert the metal rod to hold the hood in place.
  4. 2002 Toyota Tacoma Headlight Bulb Replacement: étape 4, image 1 de 2 2002 Toyota Tacoma Headlight Bulb Replacement: étape 4, image 2 de 2
    • Pinch the rubber cover and disconnect the headlight bulb.
  5. 2002 Toyota Tacoma Headlight Bulb Replacement: étape 5, image 1 de 1
    • Push down on the metal lever to release it. After you have released the lever you can remove the bulb.
  6. 2002 Toyota Tacoma Headlight Bulb Replacement: étape 6, image 1 de 1
    • Remove the headlight bulb cover when you are ready to install it.
    • Do not touch the bulb or let it touch anything to prevent it from getting damaged.
To reassemble your device, follow steps 3-5 in reverse order. At the end of step 3 make sure to push down on the hood to lock it back into place.
Drake Fenwick
Membre depuis le 02/17/21
133 Réputation
1 tutoriel rédigé
Équipe
Un commentaire
thank you, saved me alot of time.
harley cortez - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 33
Total : 1,417
