Aller au contenu principal
2003-2015 Nissan Armada Cabin Air Filter Replacement
Ce dont vous avez besoin
  1. 2003-2015 Nissan Armada Cabin Air Filter Replacement, Cabin Air Filter: étape 1, image 1 de 3 2003-2015 Nissan Armada Cabin Air Filter Replacement, Cabin Air Filter: étape 1, image 2 de 3 2003-2015 Nissan Armada Cabin Air Filter Replacement, Cabin Air Filter: étape 1, image 3 de 3
    • Open the glove box.
    • Use a Phillips #00 to remove the three screws at the top of the glove box.
    • Place your screws aside in a safe spot to use for reassembly.
    • Lift the glove box out.
  2. 2003-2015 Nissan Armada Cabin Air Filter Replacement: étape 2, image 1 de 3 2003-2015 Nissan Armada Cabin Air Filter Replacement: étape 2, image 2 de 3 2003-2015 Nissan Armada Cabin Air Filter Replacement: étape 2, image 3 de 3
    • Use a socket wrench to remove the 8 mm bolt securing the plastic cover to the cabin air filter.
    • Remove the plastic cover and you should see two air filters next to each other.
  3. 2003-2015 Nissan Armada Cabin Air Filter Replacement: étape 3, image 1 de 3 2003-2015 Nissan Armada Cabin Air Filter Replacement: étape 3, image 2 de 3 2003-2015 Nissan Armada Cabin Air Filter Replacement: étape 3, image 3 de 3
    • Carefully remove the filters starting with the left one as its easier to remove.
    • Now remove the one on the right side.
    • If you are struggling, use your fingers to slide it over.
    • Place the dirty air filters to the side and have the new ones ready.
  4. 2003-2015 Nissan Armada Cabin Air Filter Replacement: étape 4, image 1 de 3 2003-2015 Nissan Armada Cabin Air Filter Replacement: étape 4, image 2 de 3 2003-2015 Nissan Armada Cabin Air Filter Replacement: étape 4, image 3 de 3
    • Place the first filter to the right side with the airflow arrows pointing down.
    • Insert the second air filter, to the left of the first filter.
Kenneth Maldonado
Membre depuis le 09/23/23
109 Réputation
1 tutoriel rédigé
Équipe
Austin Community College, Team 1-8, Watkins Fall 2023 Membre de l'équipe Austin Community College, Team 1-8, Watkins Fall 2023
AUSTINCC-WATKINS-F23S1G8
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 50
Total : 182
