Introduction
If your 2003-2008 Pontiac Vibe suffers from symptoms like shaking or vibrating, engine rattling, increased gas mileage, or increased exhaust emissions, there’s a chance you need to replace the air fuel sensor.
This guide will help you replace the air fuel sensor on your 2003-2008 Pontiac Vibe. You will need an air fuel sensor, a socket wrench, and an O2 sensor socket for this repair.
Important note: your car must be completely off to complete this repair!
Ce dont vous avez besoin
Open the hood and locate the old air fuel sensor.
The air fuel sensor is located above the catalytic converter (upstream).
Turn your ignition on.
Check your dashboard to see if the check engine light is still on.
If the light is still on, turn the car off and wait a few minutes. Then turn the car back on and check the light again.
If the check engine light is still on, then use a code reader to see what is wrong with the car.
Un commentaire
STEP 3 SAYS "Take the 5-point O2 sensor wrench and socket and put it on the other end (downstream) of the old air fuel sensor." DOWNSTREAM? I thought we were working on UPSTREAM. I'm goin fishing !!!
