Introduction
Without a working battery, your car won't start. Replacement is the best long-term solution for this for a dead battery. You could get a boost from another car using jumper cables, but there's a chance the battery will die soon afterwards. Although the chance of shocking yourself is not very high, grounding yourself is recommended. Wearing rubber gloves is also recommended.
Outils
Pièces
Aucune pièce spécifiée.
Locate the latch to open your hood, normally located by your left foot when sitting in the driver's seat.
After lifting the latch, open your hood and securely hold it up.
To reassemble the battery, follow these instructions in reverse order.
9 autre(s) ont terminé cette réparation.
2 commentaires
A 9 Volt battery plugged into the Cigarette Lighter Socket will save the SETTINGS; just keep it handy in the glove box because those batteries eventually fail.
