Aller au contenu principal
2003-2007 Honda Accord Spark Plugs Replacement
Ce dont vous avez besoin
  1. 2003-2007 Honda Accord Spark Plugs Replacement, Opening the Hood: étape 1, image 1 de 2 2003-2007 Honda Accord Spark Plugs Replacement, Opening the Hood: étape 1, image 2 de 2
    • Locate the hood latch beside the driver's side door, next to the left foot rest.
    • Pull the latch toward you to release the hood.
  2. 2003-2007 Honda Accord Spark Plugs Replacement: étape 2, image 1 de 2 2003-2007 Honda Accord Spark Plugs Replacement: étape 2, image 2 de 2
    • Walk around to the front of the vehicle.
    • Slide your hand under the hood, directly above the Honda emblem. Locate and pull the hood tab to unlock the hood.
    • Once the tab is released, lift the hood up.
  3. 2003-2007 Honda Accord Spark Plugs Replacement: étape 3, image 1 de 2 2003-2007 Honda Accord Spark Plugs Replacement: étape 3, image 2 de 2
    • Use your left hand to hold the hood up. Locate the hood stand and pull it out of the clip.
    • Place the tip of the hood stand into the hole located in the upper left of the hood.
    • You can now let the hood rest on the stand.
  4. 2003-2007 Honda Accord Spark Plugs Replacement, Spark Plugs: étape 4, image 1 de 2 2003-2007 Honda Accord Spark Plugs Replacement, Spark Plugs: étape 4, image 2 de 2
    • Use a 10 mm hex driver or socket to remove the four screws that hold the spark plug cover in place.
    • Lift the plastic cover and set it aside.
  5. 2003-2007 Honda Accord Spark Plugs Replacement: étape 5, image 1 de 3 2003-2007 Honda Accord Spark Plugs Replacement: étape 5, image 2 de 3 2003-2007 Honda Accord Spark Plugs Replacement: étape 5, image 3 de 3
    • Remove the spark plug wire by pinching the locking tabs on either side of it and pulling it out.
  6. 2003-2007 Honda Accord Spark Plugs Replacement: étape 6, image 1 de 2 2003-2007 Honda Accord Spark Plugs Replacement: étape 6, image 2 de 2
    • Use a 10 mm hex driver or socket to remove the four spark plug boot screws.
  7. 2003-2007 Honda Accord Spark Plugs Replacement: étape 7, image 1 de 3 2003-2007 Honda Accord Spark Plugs Replacement: étape 7, image 2 de 3 2003-2007 Honda Accord Spark Plugs Replacement: étape 7, image 3 de 3
    • Lift the boot screws out of the spark plug bores.
  8. 2003-2007 Honda Accord Spark Plugs Replacement: étape 8, image 1 de 2 2003-2007 Honda Accord Spark Plugs Replacement: étape 8, image 2 de 2
    • Locate the spark plug at the bottom of the bore.
    • Use a ratchet, extension, and 5/8 inch socket to remove the plug by turning counterclockwise until it's free.
  9. 2003-2007 Honda Accord Spark Plugs Replacement: étape 9, image 1 de 3 2003-2007 Honda Accord Spark Plugs Replacement: étape 9, image 2 de 3 2003-2007 Honda Accord Spark Plugs Replacement: étape 9, image 3 de 3
    • Pull the plug out of the bore.
  10. 2003-2007 Honda Accord Spark Plugs Replacement: étape 10, image 1 de 1
    • Determine if the spark plug needs to be replaced by examining the gap for the problems listed below:
    • The gap is bridged by corrosion.
    • The gap is too large.
    • The area around the gap is black and dark.
  11. 2003-2007 Honda Accord Spark Plugs Replacement: étape 11, image 1 de 1
    • If the spark plug doesn't need to be replaced, return it to the spark plug bore. If it does need to be replaced, use a new one.
    • Use of Anti-Seize on the thread of spark plug is highly recommended to ensure threads don't get damaged while tightening.
    • Use a ratchet, extension, and 5/8 inch socket to tighten the spark plug by turning clockwise. Use your hand to tighten as well.
    • If a torque wrench is available, tighten to 13 ft-lbs.
    • Repeat Steps 10-13 for the three remaining spark plugs.
After reinstalling all four spark plugs, follow Steps 3-9 in reverse order to reattach the spark plug cover and close the car's hood.
36 autres ont terminé cette réparation.
Shaun MacDonald
Membre depuis le 10/03/12
2 558 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 24-27, Regan Fall 2012 Membre de l'équipe Cal Poly, Team 24-27, Regan Fall 2012
CPSU-REGAN-F12S24G27
4 membres
24 tutoriels rédigés
7 commentaires
Great instructions! I was able to change them pretty quickly.
JOEL DENNIS - Réponse
First rule of thumb when changing spark plugs is to do it when the engine is cold. If you don't have a torque wrench it's ok, you can still tighten them properly. Easiest thing to do is put the new plug in the spark plug socket, attach the extension (8 or 10 in. is perfect) but not the ratchet. Thread the plug in until it is snug, then attach the ratchet to tighten. Most spark plug manufacturers put on the box (especially NGK) how much to tighten. Usually if the plug has no gasket, tighten 1/16 to 1/8 of a turn. If it has a gasket, tighten 1/2 to 2/3 of a turn. For an '05 Accord 4 cyl. they have a gasket.
wingmaneh - Réponse
Thanks for the clear instructions & photos!
Steve T - Réponse
I appreciate the thorough and precise instructions. I would add using anti-seize on new plug threads.
ssnider727 - Réponse
On an '05 Accord, are there any wires that need to be replaced at a regular interval?
Ryan Roux - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 11
7 derniers jours : 75
30 derniers jours : 363
Total : 100,859
