Aller au contenu principal
2003-2006 Chevrolet Silverado Headlight Bulb Replacement
Ce dont vous avez besoin
  1. 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Preparation: étape 1, image 1 de 3 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Preparation: étape 1, image 2 de 3 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Preparation: étape 1, image 3 de 3
    • Turn your vehicle off, and let the engine bay cool before starting the following steps.
    • First, open the driver side door, and reach under the steering wheel and release the latch to open up the hood of your truck.
    • Next, walk over to either of the headlights and remove the pin above the headlight to release the housing unit.
    • Make sure to put the pin in a safe location so you can lock in the housing once you finish replacing the light bulbs.
  2. 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Removing the old lights: étape 2, image 1 de 3 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Removing the old lights: étape 2, image 2 de 3 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Removing the old lights: étape 2, image 3 de 3
    • Pinch the blue clips and remove them from the back of the wiring harness.
    • After removing the pin, you should now be able to tilt the headlight downward to gain access to all of the wires.
    • Twist the light bulb counter clockwise and gently remove the harness and the light bulb.
  3. 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Inserting the new lightbulb: étape 3, image 1 de 3 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Inserting the new lightbulb: étape 3, image 2 de 3 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Inserting the new lightbulb: étape 3, image 3 de 3
    • Unbox your new low beam light, and insert it into the same hole you took the old one out of.
    • Be sure to twist the bulb clockwise until it locks into place with the harness pointing down.
    • Plug the blue wiring harness back in until you hear a click, and it should now be locked back into place.
  4. 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Putting the headlight in: étape 4, image 1 de 3 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Putting the headlight in: étape 4, image 2 de 3 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Putting the headlight in: étape 4, image 3 de 3
    • Begin to replace the headlight housing back into its original place by tucking in the wires.
    • Grab the pin that you took out at the beginning and insert it back into the housing unit.
    • Align the housing back with the guide holes for the pin.
  5. 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Repeat: étape 5, image 1 de 2 2003-2006 Chevrolet Silverado Headlight Bulb Replacement, Repeat: étape 5, image 2 de 2
    • Follow steps 1-4 for the other headlight to replace the low beam headlight.
    • Make sure to keep track of all of your parts and dispose of your old bulbs properly.
    • Be sure to check your headlight alignment. This can be done by a professional or through Youtube videos.
To replace the other light bulb just follow the same steps as above.
5 autres ont terminé cette réparation.
Alisson Silva
Membre depuis le 09/11/15
197 Réputation
1 tutoriel rédigé
Équipe
Sam Houston State, Team 16-3, Nardone Fall 2015 Membre de l'équipe Sam Houston State, Team 16-3, Nardone Fall 2015
SHSU-NARDONE-F15S16G3
4 membres
1 tutoriel rédigé
Un commentaire
FYI: don't touch the bulbs with bare hands. The oil from your fingers will cause them to burn out early.
Jay Wilhoite - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 11
30 derniers jours : 53
Total : 41,476
