Aller au contenu principal
2003 Chevrolet Cavalier Engine Air Filter Replacement
Ce dont vous avez besoin
  1. 2003 Chevrolet Cavalier Engine Air Filter Replacement, Engine Air Filter: étape 1, image 1 de 2 2003 Chevrolet Cavalier Engine Air Filter Replacement, Engine Air Filter: étape 1, image 2 de 2
    • Pull the hood release lever.
    • This lever is located inside the cabin of the car to the left of the pedals.
  2. 2003 Chevrolet Cavalier Engine Air Filter Replacement: étape 2, image 1 de 2 2003 Chevrolet Cavalier Engine Air Filter Replacement: étape 2, image 2 de 2
    • Pull up on the hood slightly and lift the safety latch.
    • The hood will not open unless the safety latch has been lifted.
  3. 2003 Chevrolet Cavalier Engine Air Filter Replacement: étape 3, image 1 de 2 2003 Chevrolet Cavalier Engine Air Filter Replacement: étape 3, image 2 de 2
    • Open the hood and hold it with one hand.
    • Grab the prop rod in the other hand.
    • Insert the prop rod into one of the slots in the hood to secure it in place.
    • Make sure the prop rod is secure in the slot otherwise the hood may fall.
  4. 2003 Chevrolet Cavalier Engine Air Filter Replacement: étape 4, image 1 de 3 2003 Chevrolet Cavalier Engine Air Filter Replacement: étape 4, image 2 de 3 2003 Chevrolet Cavalier Engine Air Filter Replacement: étape 4, image 3 de 3
    • Unclip the wiring harness from the retaining clamps with a flathead screwdriver.
    • Pull the wiring harness out of the clamps.
  5. 2003 Chevrolet Cavalier Engine Air Filter Replacement: étape 5, image 1 de 2 2003 Chevrolet Cavalier Engine Air Filter Replacement: étape 5, image 2 de 2
    • Unscrew the four cover-mounting screws holding the air filter cover on.
    • The screws do not come out of the filter housing.
  6. 2003 Chevrolet Cavalier Engine Air Filter Replacement: étape 6, image 1 de 1
    • Separate the housing halves to access the air filter element.
  7. 2003 Chevrolet Cavalier Engine Air Filter Replacement: étape 7, image 1 de 3 2003 Chevrolet Cavalier Engine Air Filter Replacement: étape 7, image 2 de 3 2003 Chevrolet Cavalier Engine Air Filter Replacement: étape 7, image 3 de 3
    • Remove the old air filter.
    • Place the new filter in the housing.
    • The new air filter will sit comfortably in place without wobbling.
Dawson Stroik
Membre depuis le 10/05/23
145 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 21
Total : 81
