Aller au contenu principal
2003 Toyota Solara Tail Light Replacement
Ce dont vous avez besoin
  1. 2003 Toyota Solara Tail Light Replacement, Tail Light: étape 1, image 1 de 1
    • Park the vehicle and turn off the engine.
    • Step on the brake pedal to confirm whether or not the tail light is responsive.
  2. 2003 Toyota Solara Tail Light Replacement: étape 2, image 1 de 3 2003 Toyota Solara Tail Light Replacement: étape 2, image 2 de 3 2003 Toyota Solara Tail Light Replacement: étape 2, image 3 de 3
    • Reach underneath the steering wheel. Then, place your hand to the left to remove the fuse box cover.
  3. 2003 Toyota Solara Tail Light Replacement: étape 3, image 1 de 2 2003 Toyota Solara Tail Light Replacement: étape 3, image 2 de 2
    • Reference the fuse box guide on the back of the cover.
    • Locate the fuse number that corresponds to the tail light (2nd column, last row).
    • Replace the tail lamp if the fuse is still functional.
  4. 2003 Toyota Solara Tail Light Replacement: étape 4, image 1 de 2 2003 Toyota Solara Tail Light Replacement: étape 4, image 2 de 2
    • Open the vehicle's trunk.
    • Unscrew the plastic fastenings located inside the trunk.
    • Detach the panel covering the tail light.
  5. 2003 Toyota Solara Tail Light Replacement: étape 5, image 1 de 3 2003 Toyota Solara Tail Light Replacement: étape 5, image 2 de 3 2003 Toyota Solara Tail Light Replacement: étape 5, image 3 de 3
    • Untwist the wired socket to expose the lamp bulb.
    • Check the bulb for discoloration (if it is clouded, replace the bulb).
  6. 2003 Toyota Solara Tail Light Replacement: étape 6, image 1 de 2 2003 Toyota Solara Tail Light Replacement: étape 6, image 2 de 2
    • Insert the new bulb into the socket.
    • Push until there is an audible "click".
To reassemble the tail lamp, follow these instructions in reverse order.
2 autres ont terminé cette réparation.
Melissa Spinali
Membre depuis le 04/28/17
107 Réputation
1 tutoriel rédigé
Équipe
UC Davis, Team S2-G2, Cole Spring 2017 Membre de l'équipe UC Davis, Team S2-G2, Cole Spring 2017
UCD-COLE-S17S2G2
3 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 17
30 derniers jours : 96
Total : 2,978
