Aller au contenu principal
2004 - 2008 Acura TSX (CL9) Spark Plug Replacement
Ce dont vous avez besoin
  1. 2004 - 2008 Acura TSX (CL9) Spark Plug Replacement, Opening the hood: étape 1, image 1 de 1
    • Locate the hood latch beside the driver's side door, right next to the left foot rest.
    • Pull the latch, should here a pop noise to know the hood has unlatched.
    • Walk in front of the car, reach your hand under the front of the hood to locate the latch.
    • Prop the latch and locate the spark plug cover.
  2. 2004 - 2008 Acura TSX (CL9) Spark Plug Replacement, Removing the cover: étape 2, image 1 de 2 2004 - 2008 Acura TSX (CL9) Spark Plug Replacement, Removing the cover: étape 2, image 2 de 2
    • Remove the cover where the Spark Plugs are located
    • Use a 10 mm hex driver or socket to remove the four screws that hold the spark plug cover in place
    • Follow the Green circles
  3. 2004 - 2008 Acura TSX (CL9) Spark Plug Replacement, Remove the Spark Plug Wires: étape 3, image 1 de 2 2004 - 2008 Acura TSX (CL9) Spark Plug Replacement, Remove the Spark Plug Wires: étape 3, image 2 de 2
    • Use a 10 mm hex driver or socket to remove the four screws that are holding the Spark Plug wires in place.
    • Remove the spark plug wire by pinching the locking tabs on either side of it and pulling it out.
  4. 2004 - 2008 Acura TSX (CL9) Spark Plug Replacement, Remove Clips From Ignition Coil: étape 4, image 1 de 2 2004 - 2008 Acura TSX (CL9) Spark Plug Replacement, Remove Clips From Ignition Coil: étape 4, image 2 de 2
    • Once clips are removed,
    • Pull the remove the Ignition Coil out and place them in order the way you have pulled them out.
    • You should see 4 holes where the spark plugs are located.
  5. 2004 - 2008 Acura TSX (CL9) Spark Plug Replacement, Remove Spark Plugs: étape 5, image 1 de 3 2004 - 2008 Acura TSX (CL9) Spark Plug Replacement, Remove Spark Plugs: étape 5, image 2 de 3 2004 - 2008 Acura TSX (CL9) Spark Plug Replacement, Remove Spark Plugs: étape 5, image 3 de 3
    • Locate the spark plug at the bottom of the bore.
    • Use a ratchet, extension, and 5/8 socket to remove the plug by turning counterclockwise until it's free.
    • You can use a spark plug socket for an easier removal.
  6. 2004 - 2008 Acura TSX (CL9) Spark Plug Replacement: étape 6, image 1 de 1
    • Pull the plug out of the bore.
  7. 2004 - 2008 Acura TSX (CL9) Spark Plug Replacement: étape 7, image 1 de 3 2004 - 2008 Acura TSX (CL9) Spark Plug Replacement: étape 7, image 2 de 3 2004 - 2008 Acura TSX (CL9) Spark Plug Replacement: étape 7, image 3 de 3
    • Determine if the spark plug needs to be replaced by examining the gap for the problems listed below:
    • The gap is bridged by corrosion.
    • The gap is too large.
    • The area around the gap is black and dark.
    • If the spark plug doesn't need to be replaced, return it to the spark plug bore. If it does need to be replaced, use a new one.
    • Use a ratchet, extension, and 5/8 socket to tighten the spark plug by turning clockwise. Use your hand to tighten as well.
  8. 2004 - 2008 Acura TSX (CL9) Spark Plug Replacement, Tip: étape 8, image 1 de 2 2004 - 2008 Acura TSX (CL9) Spark Plug Replacement, Tip: étape 8, image 2 de 2
    • If you don't want to purchase a spark plug socket.
    • you can use a regular 16 hex mm socket.
    • Have a magnetic extension pen to gently connect the spark plugs and remove it out the bore.
  9. 2004 - 2008 Acura TSX (CL9) Spark Plug Replacement: étape 9, image 1 de 1
    • Repeat steps from 6-8 removing each plugs and checking if they are bad.
    • Once you double check each spark plugs. Reverse steps and make sure bolts are tight and spark plug wires are snapped in perfectly.
    • You have completed Spark plugs removal for Acura TSX.
After reinstalling all 4 spark plugs, follow steps 1-4 in reverse order and reattach the spark plug cover and close the hood.
5 autres ont terminé cette réparation.
Un commentaire
Is there are particular torque the spark plugs need to be tightened to?
Harrison DS - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 27
30 derniers jours : 121
Total : 13,302
