Aller au contenu principal
2004-2008 Ford F150 Tail Light Bulb Replacement
Ce dont vous avez besoin
  1. 2004-2008 Ford F150 Tail Light Bulb Replacement, Tail Light Bulb: étape 1, image 1 de 1
    • Park the vehicle on a level surface.
    • Turn the vehicle off.
    • If the vehicle is not turned off, there is a risk of electrocution upon removal of the tail light.
  2. 2004-2008 Ford F150 Tail Light Bulb Replacement: étape 2, image 1 de 1
    • Lower the tailgate.
  3. 2004-2008 Ford F150 Tail Light Bulb Replacement: étape 3, image 1 de 3 2004-2008 Ford F150 Tail Light Bulb Replacement: étape 3, image 2 de 3 2004-2008 Ford F150 Tail Light Bulb Replacement: étape 3, image 3 de 3
    • Use the 8mm socket wrench to remove both of the mounting bolts.
    • An 8mm crescent wrench can be used in place of the 8mm socket wrench.
  4. 2004-2008 Ford F150 Tail Light Bulb Replacement: étape 4, image 1 de 2 2004-2008 Ford F150 Tail Light Bulb Replacement: étape 4, image 2 de 2
    • Remove the tail light by pulling the tail light housing straight back, away from the vehicle.
    • If the tail light housing is too difficult to remove use a thin, stiff piece of plastic as a pry bar to aid in removing the tail light housing.
    • If a pry bar is used, take caution to not scratch the paint of the vehicle.
  5. 2004-2008 Ford F150 Tail Light Bulb Replacement: étape 5, image 1 de 1
    • Twist the upper socket counter clockwise.
    • Pull back to remove the socket from the tail light assembly.
  6. 2004-2008 Ford F150 Tail Light Bulb Replacement: étape 6, image 1 de 2 2004-2008 Ford F150 Tail Light Bulb Replacement: étape 6, image 2 de 2
    • Pull the bulb out of the socket.
    • When handling the replacement bulb, be careful to minimize contact with the bulb itself; as the oils from your hand can decrease the lifespan of the bulb.
6 autres ont terminé cette réparation.
Eric Carnes
Membre depuis le 06/20/18
274 Réputation
1 tutoriel rédigé
Équipe
Washington State, Team S1-G5, Hope Summer 2018 Membre de l'équipe Washington State, Team S1-G5, Hope Summer 2018
WSU-HOPE-SU18S1G5
3 membres
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 16
30 derniers jours : 58
Total : 11,172
