Aller au contenu principal
Pour réparer ensemble - Je crée un compte
2004-2008 Mazda RX-8 Air Filter Replacement
    1. 2004-2008 Mazda RX-8 Air Filter Replacement, Air Filter: étape 1, image 1 de 1
      • Begin by opening the hood of the vehicle and locating the air filter cover.
      • The air filter is located in the middle of the front of the vehicle covered by a large black rectangular cover.
      Demander à FixBot
      Ajouter un commentaire
    2. 2004-2008 Mazda RX-8 Air Filter Replacement: étape 2, image 1 de 3 2004-2008 Mazda RX-8 Air Filter Replacement: étape 2, image 2 de 3 2004-2008 Mazda RX-8 Air Filter Replacement: étape 2, image 3 de 3
      • Locate the two tabs on either side of the front of the air filter cover. Grab and pop open these two tabs.
      • Push the air filter cover open with your fingers. The air filter will now be visible and begin to pop up.
      • Once the air filter pops up, you can grab it with your hands and begin to remove it from the cover that is still being held open.
      Demander à FixBot
    3. 2004-2008 Mazda RX-8 Air Filter Replacement: étape 3, image 1 de 2 2004-2008 Mazda RX-8 Air Filter Replacement: étape 3, image 2 de 2
      • Gently pull the entire air filter out of the opened cover. This might take more than one set of hands in order to keep the cover open during removal.
      • The air filter is now fully removed and outside of the air filter cover. Obtain a new air filter to replace the old one.
      Demander à FixBot
    4. 2004-2008 Mazda RX-8 Air Filter Replacement: étape 4, image 1 de 3 2004-2008 Mazda RX-8 Air Filter Replacement: étape 4, image 2 de 3 2004-2008 Mazda RX-8 Air Filter Replacement: étape 4, image 3 de 3
      • Pry apart the cover of the air filter again to begin inserting your new air filter.
      • Gently push the new air filter back into the opened air filter cover the same way you removed it. The air filter will fall back into its resting position.
      • Once the new air filter has been fully inserted into the cover, close the cover and push the two tabs on the outside of the cover closed.
      Demander à FixBot
Ligne d'arrivée
2 autres ont terminé cette réparation.
Laura Pritchard
Membre depuis le 04/20/15
199 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 8-4, Regan Spring 2015 Membre de l'équipe Cal Poly, Team 8-4, Regan Spring 2015
CPSU-REGAN-S15S8G4
5 membres
16 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 31
Total : 4,828
