Aller au contenu principal
Pour réparer ensemble - Je crée un compte
2004-2008 Mazda RX-8 Oil/Oil Filter Replacement
Ce dont vous avez besoin
    1. 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement, Oil/Oil Filter: étape 1, image 1 de 1
      • Gather all the required items.
      Demander à FixBot
      Ajouter un commentaire
    2. 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 2, image 1 de 1
      • Open the hood by pulling the hood latch.
      • The hood latch is located down and to the left of the steering wheel by the trunk button.
      Demander à FixBot
    3. 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 3, image 1 de 1
      • Lift the hood and hold it open with the hood prop bar.
      Demander à FixBot
    4. 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 4, image 1 de 1
      • Remove the plastic engine cover by lifting up.
      Demander à FixBot
    5. 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 5, image 1 de 2 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 5, image 2 de 2
      • Jack up the car using the car jack.
      • Caution: If at all possible, use a dedicated car jack instead of the emergency jack.
      • The emergency jack is not designed for frequent uses and could sustain damage if overused. If the emergency jack must be used, do not put any body part under the car until jack stands are secured.
      • Be sure to place the car jack under the proper reinforced areas.
      • The reinforced area is located just behind the front wheels, between two bumps in the undercarrage frame.
      • Reference the car's manual if you require more information on how to safely jack up your car without damaging the frame.
      Demander à FixBot
    6. 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 6, image 1 de 1
      • Place a jack stand under the car near the jack.
      • Lower the jack until the weight of the car is on the jack stand.
      • Standing beside the car, lightly shake the car to ensure that it is securely on the jack stand before getting under the car.
      Demander à FixBot
    7. 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 7, image 1 de 3 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 7, image 2 de 3 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 7, image 3 de 3
      • Place the oil pan under the drain plug of the oil pan.
      • The oil pan is located under the car between the front wheels.
      • The drain plug will be on the left side of the oil pan when facing the front of the car.
      Demander à FixBot
    8. 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 8, image 1 de 2 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 8, image 2 de 2
      • Loosen the drain plug with the crescent wrench.
      • If you are using a socket, you will need a 19mm socket to remove the oil pan nut.
      • Once the plug is loose, unscrew it by hand letting the oil flow out.
      • Caution: If the engine has not cooled down before the oil is drained, the oil will be hot. Use proper precautions to avoid burns.
      Demander à FixBot
    9. 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 9, image 1 de 3 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 9, image 2 de 3 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 9, image 3 de 3
      • Leave the car for about 20 minuites to allow all the oil to drain.
      • Once the oil stops dripping, screw the drain plug back in by hand.
      • Tighten the drain plug with the crescent wrench until it is secure. Do not over tighten as the plug will have to be removed for the next oil change.
      • The torque spec on the drain plug is 29.4-39.2 N-m (21.7-28.9 ft-lbf). Over or under tightening the plug could damage the oil pan and lead to future leaks.
      Demander à FixBot
    10. 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 10, image 1 de 1
      • Jack the car up unitil the weight of the car is on the jack, and then remove the jack stand.
      • After the jack stand is removed, lower the car using the jack, and then remove the jack from under the car.
      Demander à FixBot
    11. 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 11, image 1 de 3 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 11, image 2 de 3 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 11, image 3 de 3
      • Locate the old oil filter.
      • It should be located in the back of the engine bay, behind the engine.
      Demander à FixBot
    12. 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 12, image 1 de 2 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 12, image 2 de 2
      • Using the socket wrench, extender, and oil filter wrench, loosen and remove the old oil filter.
      • The oil filter may be stuck on very tight. Some may find it easier to use a gloved hand to begin to loosen the filter initially.
      Demander à FixBot
    13. 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 13, image 1 de 2 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 13, image 2 de 2
      • Take the new filter out of the box.
      • Place a small amount of oil on the o-ring and threads of the new filter make it easier to remove in the future.
      Demander à FixBot
    14. 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 14, image 1 de 2 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 14, image 2 de 2
      • Screw new oil filter into the spot where the old one was using your hand.
      • Tighten the filter using the filter wrench.
      • Be sure not to over tighten the filter.
      Demander à FixBot
    15. 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 15, image 1 de 2 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 15, image 2 de 2
      • Unscrew the yellow oil fill cap using your hands.
      Demander à FixBot
    16. 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 16, image 1 de 1
      • Using the funnel, add approximately 3.7 quarts of oil into the fill hole.
      Demander à FixBot
    17. 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 17, image 1 de 2 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 17, image 2 de 2
      • Screw the oil fill cap back on and tighten.
      Demander à FixBot
    18. 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 18, image 1 de 1
      • Wait a couple minutes for the oil to settle at the bottom of the oil pan.
      • Using the dip stick, ensure the oil level is within the recommended range.
      Demander à FixBot
    19. 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 19, image 1 de 2 2004-2008 Mazda RX-8 Oil/Oil Filter Replacement: étape 19, image 2 de 2
      • Wipe off the dipstick before to remove any excess oil on it.
      • Put the dipstick back in the dipstick hole in the engine bay and push it all the way down.
      • Pull the dipstick back up and look at where the oil line is with respect to the markings on the dipstick.
      • The low oil line is the lower raised line on the dipstick, and the high oil line is the higher raised line. You want the oil level to be in between the two.
      • Because the RX-8 engine is designed to burn oil during operation, I suggest you try to keep the oil in the upper third of the fill range to avoid driving with low oil in the future.
      • If the oil level is too low, add more clean oil into the oil fill spout. If the oil level is too high it may be necessary to drain the oil and repeat the guide over again to avoid engine damage from excess engine oil.
      Demander à FixBot
Ligne d'arrivée
5 autres ont terminé cette réparation.
Conner Walker
Membre depuis le 05/15/15
215 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 8-4, Regan Spring 2015 Membre de l'équipe Cal Poly, Team 8-4, Regan Spring 2015
CPSU-REGAN-S15S8G4
5 membres
16 tutoriels rédigés
1 commentaire de tutoriel
Great! Thanks, I'm on it!
ilovejunkmail - Réponse Partager
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 19
30 derniers jours : 85
Total : 30,149
