Introduction
This guide provides instructions on how to change your Lexus LS430 cabin air filter. Cabin air filters usually need replacement every ~40,000 miles. An unchanged air filter lets harmful odors and contaminants pass through which is harmful to one's health so it is crucial to replace them.
This repair uses an air filter (part number 87139-50030). You may obtain this OEM, or opt for aftermarket ones. The 2004-2006 models of the LS430 experienced a refresh which included some changes in the glove compartment, but otherwise, this guide may be very similar to the 2001-2003 models.
Ce dont vous avez besoin
Enter through the front passenger door.
Release the glove compartment by pulling at the hinge.
Remove the shelf obstructing our view. With your hand underneath, push up. Once disconnected from the bottom latch, get a good grip and pull to the left.
Align the three tabs on the air filter housing lid and push forward to clip it back on.
Align the base of the cabin air filter cover to ensure it sits flush against the bottom, then push to securely clip it back on.
To reattach the shelf, insert it into the base of the glove compartment first. Then, secure it by gripping and maneuvering it into the hole on the right side of the compartment.
Congratulations, you've replaced your cabin air filter!
Congratulations on your cabin air filter replacement! Enjoy another 40,000 miles of worry-free breathing.
