Introduction
If your Nissan Pathfinder 2011 Check Engine light has come on and a mechanic has pointed to a faulty oxygen sensor, don't worry. This is one of the most common car repairs out there, and the good news is that you don't need to be a seasoned mechanic to fix it yourself! The replacement process is more straightforward than it sounds. If you have a basic set of tools and can set aside an hour or two, you can absolutely handle this at home and save yourself a significant amount in labor costs!
In this guide, we'll walk through every step in plain, simple language, no mechanical background required. We'll cover what tools and parts you'll need, how to safely get to the part, and exactly how to swap out the old sensor for a new one. Just take it one step at a time, and you'll have it done before you know it.
Let's get started!
Disconnect the battery's negative terminal to prevent electrical shocks and reset the ECU.
