Introduction
Use this guide to replace the broken sliding mechanism of a 2005-2011 Honda Civic center console armrest. The sliding mechanism is the component responsible for connecting the armrest lid to the center console and enables its sliding movement. Due to the broken sliding mechanism inside, the console armrest lid is disconnected from the center console while a portion of the lid still remains attached. Follow this guide for a step-by-step to replace a new sliding mechanism. No special skills are necessary, but having a basic toolkit will be helpful.
Ce dont vous avez besoin
Press down the second-half armrest lid and keep it held in place.
Use a flathead screwdriver or plastic prying tool to pry open the armrest center console back panel.
Remove the back panel.
Once you remove the back panel, take notice of the metal pin head on the sides of the armrest center console.
Make sure the pinion gear is in the center of the U-shape bracket, then grab the rack and raise it up to the sliding mechanism.
With one hand holding the rack, use your other hand to slowly slide the sliding mechanism backward to get access to the two screws on the metal plates at the top.
Position the longer metal plate side toward the sliding mechanism.
Align the holes on the metal plates with the holes on the sliding mechanism
Screw a 12 mm T15 Torx screw into the bottom hole using a T15 Torx screwdriver.
Slide down the metal plate and screw in a 12mm T15 Torx screw at the top.
Repeat the same process on the other side.
Align the three screw bosses on the second-half lid with the small holes on the sliding mechanism.
Hold the second-half lid and the sliding mechanism in place. Then, flip over to the other side.
Screw the three 12 mm T15 Torx screws into the screw bosses using a T15 Torx screwdriver.
While holding the spring in place, position the armrest lid back onto the center console.
With one hand holding the armrest lid and spring together, push the metal pin through the hole on the right side of the center console into the spring coils.
Use a pliers to push the metal pin all the way into the hole on the left of the center console.
Pull up the latch.
Slide the two small tabs protruding from the interior panel upward into the two large holes at the bottom of the sliding mechanism, then slide them down.
Screw the two 12 mm T15 Torx screws into the two screw holes underneath the latch that secure the interior panel.
