Aller au contenu principal
2005 Honda CR-V Car Visor Replacement
Ce dont vous avez besoin
  1. 2005 Honda CR-V Car Visor Replacement, Car Visor: étape 1, image 1 de 2 2005 Honda CR-V Car Visor Replacement, Car Visor: étape 1, image 2 de 2
    • Ensure that the car is parked and utilize the parking brake.
    • Press the switch on the left of the parking lever, pull it outwards, and release it when it is fixed and outward.
  2. 2005 Honda CR-V Car Visor Replacement: étape 2, image 1 de 2 2005 Honda CR-V Car Visor Replacement: étape 2, image 2 de 2
    • Remove the outer shell with a spudger.
    • When the outer shell is loose enough, remove it with your hand.
  3. 2005 Honda CR-V Car Visor Replacement: étape 3, image 1 de 3 2005 Honda CR-V Car Visor Replacement: étape 3, image 2 de 3 2005 Honda CR-V Car Visor Replacement: étape 3, image 3 de 3
    • Remove the two 4.5 mm screws from the visor with a Torx screwdriver.
    • After removing the inner layer, the sun visor is now released.
  4. 2005 Honda CR-V Car Visor Replacement: étape 4, image 1 de 2 2005 Honda CR-V Car Visor Replacement: étape 4, image 2 de 2
    • Put the 4.5 mm screw removed in the previous step in the new sun visor.
    • Tighten the screw using a Torx screwdriver.
    • Also, note that the shape of the shell is aligned with the form of the hole in the roof.
  5. 2005 Honda CR-V Car Visor Replacement: étape 5, image 1 de 2 2005 Honda CR-V Car Visor Replacement: étape 5, image 2 de 2
    • Screw in the rest of the 4.5 mm screws back in the sun visor using a Torx screwdriver.
    • Ensure that the screws are tight.
  6. 2005 Honda CR-V Car Visor Replacement: étape 6, image 1 de 3 2005 Honda CR-V Car Visor Replacement: étape 6, image 2 de 3 2005 Honda CR-V Car Visor Replacement: étape 6, image 3 de 3
    • Put the outer shell back on top of the inner shell.
    • Finally, ensure that the sun visor can be moved to the driver-side window and twisted upwards and downwards.
To replace the new sun visor with the old sun visor, follow these steps in the same order.
An Chen
Membre depuis le 04/05/23
133 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 2-24, Briggs Spring 2023 Membre de l'équipe CSU Los Angeles, Team 2-24, Briggs Spring 2023
CSULA-BRIGGS-S23S2G24
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 41
Total : 497
