Introduction
This guide will demonstrate how to replace an LED dome light for a 2006-2014 GMC Yukon. The dome light turns on when you open the door or you can turn it on while driving or in park if you need an overhead light and it's dark. Although the repair is demonstrated on a GMC Yukon 2012, you can follow the same procedure for other cars in the first generation of the GMC Yukon.
Before beginning the repair, make sure your car is off and in park. If you have used the dome light recently, make sure it has cooled off before beginning the repair as it can heat up and there is a potential to burn your fingers when replacing the bulb. No special skills are needed.
Ce dont vous avez besoin
locate the square slots furthest from the light switch and wedge the edge of the prying tool into the slot to pry out the hooks holding the lens in place.
hope this guide has helped someone!
