Aller au contenu principal
2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement
Ce dont vous avez besoin
  1. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement, Low Beam Headlight Bulb: étape 1, image 1 de 3 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement, Low Beam Headlight Bulb: étape 1, image 2 de 3 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement, Low Beam Headlight Bulb: étape 1, image 3 de 3
    • Pull the hood release in the lower left of the driver's side of your car.
    • Lift the hood of your car until it stays up on its own.
  2. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: étape 2, image 1 de 2 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: étape 2, image 2 de 2
    • Use any size flathead screwdriver to remove the screw plugs that are holding down the engine cover.
  3. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: étape 3, image 1 de 3 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: étape 3, image 2 de 3 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: étape 3, image 3 de 3
    • Remove the bottom engine cover.
  4. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: étape 4, image 1 de 2 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: étape 4, image 2 de 2
    • Use a 1/4" flathead screwdriver to remove the screw holding down the top engine cover.
  5. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: étape 5, image 1 de 3 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: étape 5, image 2 de 3 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: étape 5, image 3 de 3
    • Remove the side engine cover.
  6. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: étape 6, image 1 de 3 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: étape 6, image 2 de 3 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: étape 6, image 3 de 3
    • Use a 10 mm wrench to remove the washer fluid tube.
  7. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: étape 7, image 1 de 2 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: étape 7, image 2 de 2
    • Locate the headlight bulb's cover.
  8. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: étape 8, image 1 de 2 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: étape 8, image 2 de 2
    • Push the metal bar down to release the cover.
  9. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: étape 9, image 1 de 2 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: étape 9, image 2 de 2
    • Remove the bulb cover.
  10. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: étape 10, image 1 de 3 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: étape 10, image 2 de 3 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: étape 10, image 3 de 3
    • Twist the headlight bulb cap counterclockwise (1/4 turn) to detach.
  11. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: étape 11, image 1 de 3 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: étape 11, image 2 de 3 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: étape 11, image 3 de 3
    • Push the metal clips inward to release the headlight bulb.
    • Pull the bull out of the socket.
  12. 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: étape 12, image 1 de 2 2006-2013 Lexus IS 250 Low Beam Headlight Bulb Replacement: étape 12, image 2 de 2
    • Insert the new headlight bulb.
    • Make sure not to touch the glass part with your hands. This can cause a hot spot on the bulb, making it burn out faster. Use gloves to avoid oil and salt transfer to the bulb.
Daniel R
Membre depuis le 10/24/23
205 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 12-6, Ribeiro Fall 2023 Membre de l'équipe CSU Los Angeles, Team 12-6, Ribeiro Fall 2023
CSULA-RIBEIRO-F23S12G6
2 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 13
7 derniers jours : 67
30 derniers jours : 288
Total : 991
