Aller au contenu principal
Pour réparer ensemble - Je crée un compte
2006-2013 Toyota Corolla Brake Light Replacement
Ce dont vous avez besoin
    1. 2006-2013 Toyota Corolla Brake Light Replacement, Brake Lights: étape 1, image 1 de 3 2006-2013 Toyota Corolla Brake Light Replacement, Brake Lights: étape 1, image 2 de 3 2006-2013 Toyota Corolla Brake Light Replacement, Brake Lights: étape 1, image 3 de 3
      • Open the trunk of the vehicle.
      • Locate the taillight area that needs fixing either on the right and/or left.
      • We are fixing the left side in this guide.
      Demander à FixBot
      Ajouter un commentaire
    2. 2006-2013 Toyota Corolla Brake Light Replacement: étape 2, image 1 de 1
      • Using a flathead screwdriver, pry the 3 fasteners out.
      Demander à FixBot
    3. 2006-2013 Toyota Corolla Brake Light Replacement: étape 3, image 1 de 2 2006-2013 Toyota Corolla Brake Light Replacement: étape 3, image 2 de 2
      • Pull back the covering to reveal the taillight area.
      • Locate the brake light bulb in the brown socket at the inner end of the taillight area.
      Demander à FixBot
    4. 2006-2013 Toyota Corolla Brake Light Replacement: étape 4, image 1 de 2 2006-2013 Toyota Corolla Brake Light Replacement: étape 4, image 2 de 2
      • Rotate the brown socket counterclockwise and pull out the socket.
      • Pull the nonfunctioning light bulb from its socket and replace with the new, functioning bulb
      • Put the brown socket back in place and rotate clockwise to secure it
      • Put the covering back in place and secure the 3 fasteners. No tools are required, simply push the fasteners into position.
      Demander à FixBot
6 autres ont terminé cette réparation.
Phuong khau
Membre depuis le 09/15/20
271 Réputation
1 tutoriel rédigé
Équipe
2 commentaires de tutoriel
I had to use pliers carefully to turn the brown socket, but this worked perfectly. Thank you!
Josh - Réponse Partager
Wrong bulb #. Must order Sylvania 3157 for Brake Light .
https://www.partsource.ca/products/3157l...
fruitfly - Réponse Partager
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 46
30 derniers jours : 239
Total : 16,385
