Aller au contenu principal
Pour réparer ensemble - Je crée un compte
2006-2013 Toyota Corolla Cabin Lights Replacement
Ce dont vous avez besoin
  1. 2006-2013 Toyota Corolla Cabin Lights Replacement, Cabin Light Bulb: étape 1, image 1 de 1
    • We will now begin the repair to replace Cabin Lights for a 2006-2013 Toyota Corolla.
    Demander à FixBot
    Ajouter un commentaire
  2. 2006-2013 Toyota Corolla Cabin Lights Replacement: étape 2, image 1 de 3 2006-2013 Toyota Corolla Cabin Lights Replacement: étape 2, image 2 de 3 2006-2013 Toyota Corolla Cabin Lights Replacement: étape 2, image 3 de 3
    • Insert the end of a spudger into the narrow openings at the bottom of the light cover and pry up to release the light cover.
    • After completing this step, the lid will be loose and could fall on your face if you are not careful and catch the lid on time.
    Demander à FixBot
  3. 2006-2013 Toyota Corolla Cabin Lights Replacement: étape 3, image 1 de 2 2006-2013 Toyota Corolla Cabin Lights Replacement: étape 3, image 2 de 2
    • Remove the light cover.
    Demander à FixBot
  4. 2006-2013 Toyota Corolla Cabin Lights Replacement: étape 4, image 1 de 3 2006-2013 Toyota Corolla Cabin Lights Replacement: étape 4, image 2 de 3 2006-2013 Toyota Corolla Cabin Lights Replacement: étape 4, image 3 de 3
    • Pull back the mechanism holding the bulb in place and remove the old bulb.
    Demander à FixBot
  5. 2006-2013 Toyota Corolla Cabin Lights Replacement: étape 5, image 1 de 2 2006-2013 Toyota Corolla Cabin Lights Replacement: étape 5, image 2 de 2
    • Insert the new bulb into the end of the holder with the hole.
    • There is no specific bulb orientation for this step, either side can be inserted, and the light will still work.
    Demander à FixBot
  6. 2006-2013 Toyota Corolla Cabin Lights Replacement: étape 6, image 1 de 3 2006-2013 Toyota Corolla Cabin Lights Replacement: étape 6, image 2 de 3 2006-2013 Toyota Corolla Cabin Lights Replacement: étape 6, image 3 de 3
    • Place the other end of the bulb so it slides easily into the end of the holder.
    Demander à FixBot
  7. 2006-2013 Toyota Corolla Cabin Lights Replacement: étape 7, image 1 de 3 2006-2013 Toyota Corolla Cabin Lights Replacement: étape 7, image 2 de 3 2006-2013 Toyota Corolla Cabin Lights Replacement: étape 7, image 3 de 3
    • Insert the clip side of the light cover into the two slots for the correct orientation.
    Demander à FixBot
  8. 2006-2013 Toyota Corolla Cabin Lights Replacement: étape 8, image 1 de 2 2006-2013 Toyota Corolla Cabin Lights Replacement: étape 8, image 2 de 2
    • Press the lid down to reattach.
    • The lid should snap back into place.
    Demander à FixBot
  9. 2006-2013 Toyota Corolla Cabin Lights Replacement: étape 9, image 1 de 1
    • Slide the switch to turn the cabin light on. If it doesn't work, repeat steps 1-11 with a new bulb.
    Demander à FixBot
You have now replaced your 2006-2013 Toyota Corolla Cabin Lights!
2 autres ont terminé cette réparation.
KennethM
Membre depuis le 04/20/25
184 Réputation
1 tutoriel rédigé
Équipe
CSU Los Angeles, Team 1-3, Ribeiro Spring 2025 Membre de l'équipe CSU Los Angeles, Team 1-3, Ribeiro Spring 2025
CSULA-RIBEIRO-S25S1G3
4 membres
1 tutoriel rédigé
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 22
30 derniers jours : 96
Total : 1,276
