Aller au contenu principal
2006-2013 Toyota Corolla Headlight bulb Replacement
Ce dont vous avez besoin
  1. 2006-2013 Toyota Corolla Headlight bulb Replacement, Headlight bulb: étape 1, image 1 de 1
    • Locate the handle to open the hood
    • Open the hood of the car.
  2. 2006-2013 Toyota Corolla Headlight bulb Replacement: étape 2, image 1 de 1
    • Locate the bulb. It will be in the front and the side. (Start with side opposing the battery).
    • Twist assembly 45 degrees counterclockwise and pull straight out.
  3. 2006-2013 Toyota Corolla Headlight bulb Replacement: étape 3, image 1 de 2 2006-2013 Toyota Corolla Headlight bulb Replacement: étape 3, image 2 de 2
    • Lift up on the latch and pull. The bulb will come free from the wires
  4. 2006-2013 Toyota Corolla Headlight bulb Replacement: étape 4, image 1 de 1
    • Change the light bulb.
    • Put it back in place and twist the assembly the other way around.
  5. 2006-2013 Toyota Corolla Headlight bulb Replacement: étape 5, image 1 de 1
    • Use step 3 to 7 for the other side.
After reviewing the guideline you should be more than capable to replace an headlight by yourself.
3 autres ont terminé cette réparation.
Pièces jointes
Frantz Etienne
Membre depuis le 03/28/21
205 Réputation
1 tutoriel rédigé
1 commentaire de tutoriel
The driver's side is harder as you have to remove stuff to get to the bulb. And depending on the year it could be a push pin or bolt that holds the stuff in place.
Resist - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 8
7 derniers jours : 56
30 derniers jours : 300
Total : 12,787
