Aller au contenu principal
2006-2013 Toyota Corolla Ignition Coil Replacement
Ce dont vous avez besoin
  1. 2006-2013 Toyota Corolla Ignition Coil Replacement, Ignition Coil: étape 1, image 1 de 3 2006-2013 Toyota Corolla Ignition Coil Replacement, Ignition Coil: étape 1, image 2 de 3 2006-2013 Toyota Corolla Ignition Coil Replacement, Ignition Coil: étape 1, image 3 de 3
    • Pop the hood and remove the black plastic cover over the engine.
    • There is nothing to unscrew, or unlatch, and the cover should lift off. Once removed, the top of the engine will look like the third picture
  2. 2006-2013 Toyota Corolla Ignition Coil Replacement: étape 2, image 1 de 2 2006-2013 Toyota Corolla Ignition Coil Replacement: étape 2, image 2 de 2
    • Unplug the ignition coil you wish to replace. The coils are numbered one though four, left to right.
    • Do not unscrew the bolt on the ignition coil before this step. It makes the electrical plug more difficult to remove
  3. 2006-2013 Toyota Corolla Ignition Coil Replacement: étape 3, image 1 de 1
    • Unscrew the bolt of the coil that needs to be replaced.
    • Be sure to put the bolt in a place you will not lose it!
  4. 2006-2013 Toyota Corolla Ignition Coil Replacement: étape 4, image 1 de 2 2006-2013 Toyota Corolla Ignition Coil Replacement: étape 4, image 2 de 2
    • Pull the coil straight up and out. It should come off of the spark plug with little resistance.
  5. 2006-2013 Toyota Corolla Ignition Coil Replacement: étape 5, image 1 de 2 2006-2013 Toyota Corolla Ignition Coil Replacement: étape 5, image 2 de 2
    • Apply a pea-sized amount of grease to the new ignition coil. It should be all around the rubber tip around the bottom.
    • While not required, this step will make any future replacements much easier.
  6. 2006-2013 Toyota Corolla Ignition Coil Replacement: étape 6, image 1 de 1
    • When inserting the new ignition coil, press down lightly to ensure it is completely in place.
    • Re-plugging in the ignition coil, and re-screw it in. This can be preformed in either order.
    • Repeat steps three through five as necessary for the other three ignition coils.
2 autres ont terminé cette réparation.
Henderson Gillette
Membre depuis le 09/23/23
190 Réputation
1 tutoriel rédigé
Équipe
Austin Community College, Team 22-3, Watkins Fall 2023 Membre de l'équipe Austin Community College, Team 22-3, Watkins Fall 2023
AUSTINCC-WATKINS-F23S22G3
2 membres
3 tutoriels rédigés
1 commentaire de tutoriel
Excelente explicación, muy clara y detallada
Oscar - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 60
30 derniers jours : 347
Total : 7,305
