Aller au contenu principal
Pour réparer ensemble - Je crée un compte
2006 Honda Shadow Spirit 750 Battery Replacement
Ce dont vous avez besoin
    1. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove outer casing: étape 1, image 1 de 1
      • Remove the plastic covering, located on the left side of the bike, by pulling the piece straight off the bike.
      Demander à FixBot
      Ajouter un commentaire
    2. 2006 Honda Shadow Spirit 750 Battery Replacement, Open toolbox: étape 2, image 1 de 3 2006 Honda Shadow Spirit 750 Battery Replacement, Open toolbox: étape 2, image 2 de 3 2006 Honda Shadow Spirit 750 Battery Replacement, Open toolbox: étape 2, image 3 de 3
      • The tool box is located under the panel.
      • Using the key to the motorbike, unlock the tool box.
      • Remove the plastic bag inside holding the tools needed for basic maintenance for the motorbike.
      Demander à FixBot
    1. 2006 Honda Shadow Spirit 750 Battery Replacement, Unscrew the seat: étape 3, image 1 de 2 2006 Honda Shadow Spirit 750 Battery Replacement, Unscrew the seat: étape 3, image 2 de 2
      • Using the allen wrench, remove the screws on both sides of the bike seat.
      Demander à FixBot
    2. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove the seat: étape 4, image 1 de 1
      • Pull the rear of the seat upwards.
      • Pull the seat backwards to remove it from the bike.
      Demander à FixBot
    3. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove plastic covering: étape 5, image 1 de 1
      • Using the screwdriver, remove the screw holding the plastic cover.
      Demander à FixBot
    4. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove the fusebox: étape 6, image 1 de 1
      • Pull the cover off the battery and remove the fuse box from the cover.
      • Place the fuse box over to the side right of the bike. Do not disconnect the wires.
      Demander à FixBot
    5. 2006 Honda Shadow Spirit 750 Battery Replacement, Detach the ground wire: étape 7, image 1 de 1
      • Using the screwdriver, remove the ground wire (negative (-) cable) from the battery.
      • Place the wire over the left side of the bike.
      Demander à FixBot
    6. 2006 Honda Shadow Spirit 750 Battery Replacement, Detach the power cable: étape 8, image 1 de 1
      • Also using the screwdriver, remove the positive (+) cable from the battery.
      • Place the wire over the right side of the bike.
      • Do not let the red(+) and black(-) wires touch
      Demander à FixBot
    7. 2006 Honda Shadow Spirit 750 Battery Replacement, Remove the battery: étape 9, image 1 de 1
      • Remove the battery from the bike by pulling upwards.
      Demander à FixBot
9 autres ont terminé cette réparation.
Dazarene Cascio
Membre depuis le 10/07/14
832 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 1-7, Donnelly Fall 2014 Membre de l'équipe USF Tampa, Team 1-7, Donnelly Fall 2014
USFT-DONNELLY-F14S1G7
1 membre
2 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 105
Total : 21,572
