Aller au contenu principal
2006 Iron Horse Warrior Chainring Replacement
Ce dont vous avez besoin
  1. 2006 Iron Horse Warrior Chainring Replacement, Chainring: étape 1, image 1 de 1
    • Remove the cap covering the crank arm using the 6mm Allen Key
  2. 2006 Iron Horse Warrior Chainring Replacement: étape 2, image 1 de 2 2006 Iron Horse Warrior Chainring Replacement: étape 2, image 2 de 2
    • Screw the larger diameter threads on the crank puller into the hole you removed the cap from.
    • Slightly tighten it with an adjustable wrench.
  3. 2006 Iron Horse Warrior Chainring Replacement: étape 3, image 1 de 3 2006 Iron Horse Warrior Chainring Replacement: étape 3, image 2 de 3 2006 Iron Horse Warrior Chainring Replacement: étape 3, image 3 de 3
    • Tighten the handle on the crank puller until the arm and gears slide off of the axle.
    • The crank puller works by locking into the threads on the arm and pushing against the Isis drive axle to pry the arm and gears off. Make sure you are using the correct size crank puller, otherwise this step will not work.
    • During reassembly, add some grease to the axle to make it easier to remove the arm in the future.
  4. 2006 Iron Horse Warrior Chainring Replacement: étape 4, image 1 de 3 2006 Iron Horse Warrior Chainring Replacement: étape 4, image 2 de 3 2006 Iron Horse Warrior Chainring Replacement: étape 4, image 3 de 3
    • Remove the four 6mm hex bolts from the small chainring using the 6mm hex screwdriver. This will allow you to remove the chainring.
    • When reinstalling, apply a loctite thread compound on the threads to keep them from loosening as you ride. Also, make sure the writing on the new chainring faces the frame of the bike.
    • This chainring has a bolt circle diameter of 64 mm (BCD 64) and 22 teeth; however, you can replace it with any chainring with a BCD of 64.
Scott Kaufman
Membre depuis le 04/20/15
619 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 15-2, Amido Spring 2015 Membre de l'équipe Cal Poly, Team 15-2, Amido Spring 2015
CPSU-AMIDO-S15S15G2
4 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 10
Total : 805
